Servo control woes
Results 1 to 25 of 25
    Jan 2006
    Istanbul
    Cool
    Hi Eriswerks,
    Try using another servo or at least make sure that your servo is ok.
    Also, as you know, for most of the servos, the pulse range is from 100mS to 200mS.
    For some recent ones, range is from 60mS to 240mS (wider movement).
    Also, below is a code to consider while playing with servos.
    servo var portc.5
    freq var byte
    pulse var byte
    loop:
    pot portc.3,255,pulse
    pot portc.4,255,freq
    if pulse>240 then pulse=240 'Max pulse protection.
    If pulse<60 then pulse=60 'Min pulse protection
    If freq>30 then freq=30 'Frequency protection
    IF freq<5 then freq=5 'Frequency protection
    pulsout servo,pulse
    pause freq
    goto loop
    If you also use an LCD, you can see at what value(s) your servo does what it does and how it does.
    Talking Servo inside ???
    [QUOTE=sayzer]
    > That's really new ...
    > Mhhhh, I do not know who's inside ... but he has a lot to learn about R/C Equipments ...
    PS: ALL servos accept the 40-50 Hz frame rate ...
    Sep 2005
    Dayton, Ohio
    There must be some language in PicBasic to tell the PIC to which frequency to set the internal oscillator, but I haven't been able to find it.
    What am I (still) doing wrong here?
    Yes, there is a PicBasic command... POKE
    Use POKE to write values to ANY register in the datasheet. I usually use binary values so it's easier to see and change individual bits:
    POKE OSCON, %10110001
    (this is a made up value, I don't know what you will need exactly)
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Jan 2006
    Istanbul
    Cool
    For Acetronics,
    This is not the place for your egoistic posts.
    Why don’t you go to a primary school and show the little kids how much you know about everything you think you know about?
    You can top your ego that way.
    Angry The important thing is to speak ...
    Sayzer,
    If you want to know, I do not do care about my EGO ... no time for that.
    I'd just like you NOT to tell wrong things to those who do not know ...
    It's difficult enough to learn pic's programming ... try not to add your own errors nor misunderstandings ... verify first !!!
    Engineer, 30 years of DiY R/C, ... and always doubting ...
    Jan 2006
    Istanbul
    Cool
    Ok, Acetronics I agree . People make mistake even the ones with 30yrs of experiences.
    Could you pls tell us what happens if we send 250mS - 300mS pulse to an R/C servo at 50Hz?
    Also, 350mS and 400mS at the same freq?
    How would servo respond to these pulse(s) ?
    Pls do not make it so complicated so that we, the learners without 30 yrs of experiences, can learn something from your valuable words. Before you post your answer, make sure that your answer does not conflict with your previous posts;
    Angry Stoooooop !!!!
    Hi, sayzer
    So, you've decided to be frankly ridiculous ... your problem !!!
    250ms pulses @ 50 HZ gives .... a firm "1" ( or "0" ) level !!! you've just recreated the resettable monostable mutivibrator !!!
    Who should go back to primary school ??? ( period = 1 / frequency ... no need a highschool for that )
    your servo wil just have the little "jump" for amplifier settling at power up ... and won't move any more.
    you shouldn't have tried .... you're really boring.
    Jan 2006
    Istanbul
    Cool
    Finally you got it Acetronics,
    That is what I have been saying.
    If you look at the original loop, below, the code is sending pulses from 200mS to 400mS. In this case, the R/C servo would goto extreme edge and stop there at its max input pulse (let say 240mS). However, the code keeps sending larger pulses upto 400mS even though the R/C servo already stopped at 240mS.
    -----Orginal code-----
    loop:
    for i = 200 to 400 'When i=240, servo stops, but loop keeps increasing the pulse.
    low servo
    pulsout servo,i
    pause 18
    next i
    goto loop
    An engineer like you, age 49, should be in teaching mode rather then an egoistic mode. You should be using more explicit words to express your knowledge and have others understand what you are trying to say rather then using complicated engineering terms (an expression of egoistic unsatisfactory career to show others how much you know and others don’t)
    I will stop here. This is going nowhere.
    Let stop here Acetronics; it has no benefit to any of us.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Replies: 10
    Last Post: - 26th May 2008, 07:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 23:34
