Servo control woes
Results 1 to 25 of 25
    Sep 2005
    Dayton, Ohio
    1. Why not take the whole 8MHz issue out of the equation and run it at 4MHz? Once you get it working at 4MHz...THEN change the oscillator speed.
    2. I have some servo code at home. For a 12F629 I think. I'll dig it out and post it later.
    3. From what I remember, sending a single pulse of 1.5mS won't center the servo. You have to KEEP sending pulses to get it to move. So if it's at the extreme end, then you have to keep sending 1.5mS pulses until the servo reaches center. AND you need to keep sending those pulses if you expect it to STAY in the center. Some servos are quite a bit slower than others (check the spec sheet).
    regards
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Eriswerks, milestag is right, the servo requires updates every 50 milliseconds or so othwise most servos will shutdown and produce no torque.
    Default Damn you, inanimate object
    Thanks for your suggestions. I've whittled down the code to the bare essentials:
    @ DEVICE MCLR_OFF,WDT_OFF,PROTECT_OFF
    servo var PORTC.5
    loop:
    pulsout servo,150
    pause 18
    goto loop
    That's the entirety of it, no configuration or anything left out. That ought to center it and hold it there so long as the PIC is powered, but once again it moves all the way to one extreme and stays. I tried other pulsout values from 1 to 2000 just for the fun of it, but I keep getting the same result.
    The only thing I can think of is that the internal timer is in its LFINTOSC mode, which is 31kHz and would probably cause any pulse I care to send to look the same to the servo. There must be some language in PicBasic to tell the PIC to which frequency to set the internal oscillator, but I haven't been able to find it.
    What am I (still) doing wrong here?
    Post Datasheet !!!
    Hi,Eris
    Seems you have to read some closer the µChip Datasheet section 3 ...
    Lots ( ! ) of registers to set " by hand " that PbP do not handle !!!
    to confirm that, just program a dusty 16F84 ... will work properly with your example !!!
    The internal oscillator doesn't automatically run at 8MHz. You have to
    write to OSCCON to switch to 8MHz.
    The default value of OSCCON frequency select bits is for 4MHz. See the
    datasheet for the default value in this register at power up.
    Also PULSOUT toggles the pin twice to produce your pulse, so the initial
    state of the pin determins the polarity of the pulse.
    You want a high-going pulse for your servo, so clear the pin before the
    PULSOUT command.
    See if this works.
    @ DEVICE INTRC_OSC_NOCLKOUT, MCLR_OFF,WDT_OFF,PROTECT_OFF
    DEFINE OSC 8
    servo var PORTC.5
    i var word
    OSCCON = %01110000 ' Now it's going to run at 8MHz
    PORTC.5 = 0 ' <-- make pin low before PULSOUT (toggles high then low)
    TRISC.5 = 0  ' make pin an output
    loop:
    for i = 200 to 400
    low servo
    pulsout servo,i
    pause 18
    next i
    goto loop
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Cool
    Hi Eriswerks,
    Try using another servo or at least make sure that your servo is ok.
    Also, as you know, for most of the servos, the pulse range is from 100mS to 200mS.
    For some recent ones, range is from 60mS to 240mS (wider movement).
    Also, below is a code to consider while playing with servos.
    servo var portc.5
    freq var byte
    pulse var byte
    loop:
    pot portc.3,255,pulse
    pot portc.4,255,freq
    if pulse>240 then pulse=240 'Max pulse protection.
    If pulse<60 then pulse=60 'Min pulse protection
    If freq>30 then freq=30 'Frequency protection
    IF freq<5 then freq=5 'Frequency protection
    pulsout servo,pulse
    pause freq
    goto loop
    If you also use an LCD, you can see at what value(s) your servo does what it does and how it does.
    Talking Servo inside ???
    [QUOTE=sayzer]
    > That's really new ...
    > Mhhhh, I do not know who's inside ... but he has a lot to learn about R/C Equipments ...
    PS: ALL servos accept the 40-50 Hz frame rate ...
    Sep 2005
    Dayton, Ohio
    Yes, there is a PicBasic command... POKE
    Use POKE to write values to ANY register in the datasheet. I usually use binary values so it's easier to see and change individual bits:
    POKE OSCON, %10110001
    (this is a made up value, I don't know what you will need exactly)
    Jim Robertson
    Dayton, Ohio
    Jan 2006
    Istanbul
    Cool
    For Acetronics,
    This is not the place for your egoistic posts.
    Why don’t you go to a primary school and show the little kids how much you know about everything you think you know about?
    You can top your ego that way.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
