Servo control woes
Results 1 to 25 of 25
    Wink a Word about Bytes ...
    [QUOTE=Eriswerks]I'm trying to get down the basics of PIC servo control, and not having much luck. I'm using a 16F690 and trying to get some kind of meaningful movement out of my servo. However, the only thing my servo will do is move to one extreme of its range and sit there, perhaps scornfully.
    The offending code is:
    @ DEVICE MCLR_OFF,WDT_OFF,PROTECT_OFF
    DEFINE OSC 8
    servo var PORTC.5
    i var byte
    loop:
    for i = 200 to 400
    low servo
    pulsout servo,i
    pause 18
    next i
    goto loop
    hi,Eris
    @ 8 Mhz, pulsout resolution is 5µS ( 10µS *4 / F.Mhz)
    so, correct for that.
    for i = 200 to 400 means i should not be a byte ( i max = 255 !!! )
    so, what's happening ??? i value goes from 200 to 255 then ... back to 0 , out of the for - next loop !!! program ends.
    just change i for a WORD !!!
    Default Still no joy
    Thanks for the reply. I've changed the variable's type from BYTE to WORD, but there must be something else wrong as well - my servo still goes to one extreme and sits. Even if I do away with the loop entirely and just send it one position to center it, I'm still getting this behavior. That suggests to me that it must be timing-related, but I've tried timing some LED pulses without doing a DEFINE OSC and it confirms the 8MHz I see in the datasheet.
    Maybe if I buy the PIC some chocolates?
    Default More thoughts on the subject
    Looking through the 16F690 datasheet for anything I might have missed, I found this little nugget:
    The output of the 8 MHz HFINTOSC and 31 kHz
    LFINTOSC connects to a postscaler and multiplexer
    (see Figure 3-1). The Internal Oscillator Frequency
    select bits, IRCF<2:0> (OSCCON<6:4>), select the
    frequency output of the internal oscillators. One of eight
    frequencies can be selected via software.
    So, it seems like in order to make sure that the PIC is running at 8MHz, I should be telling it to use HFINTOSC and not LFINTOSC, and according to the diagram mentioned I should be setting the frequency select bits to 111.
    How do I go about doing that in PicBasic? Is it actually necessary to do so, or does the "intrc_osc_noclkout" that's in the include file for this chip have me covered already? I've also found mentions of putting "OSCCON = $70" in the code to set 8MHz, but I can't seem to find any real documentation on it. Is this controlling the frequency select bits? If so, do I still need to specify HFINTOSC somewhere?
    Sorry for the deluge of questions...
    Sep 2005
    Dayton, Ohio
    1. Why not take the whole 8MHz issue out of the equation and run it at 4MHz? Once you get it working at 4MHz...THEN change the oscillator speed.
    2. I have some servo code at home. For a 12F629 I think. I'll dig it out and post it later.
    3. From what I remember, sending a single pulse of 1.5mS won't center the servo. You have to KEEP sending pulses to get it to move. So if it's at the extreme end, then you have to keep sending 1.5mS pulses until the servo reaches center. AND you need to keep sending those pulses if you expect it to STAY in the center. Some servos are quite a bit slower than others (check the spec sheet).
    regards
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Eriswerks, milestag is right, the servo requires updates every 50 milliseconds or so othwise most servos will shutdown and produce no torque.
    Default Damn you, inanimate object
    Thanks for your suggestions. I've whittled down the code to the bare essentials:
    servo var PORTC.5
    loop:
    pulsout servo,150
    pause 18
    goto loop
    That's the entirety of it, no configuration or anything left out. That ought to center it and hold it there so long as the PIC is powered, but once again it moves all the way to one extreme and stays. I tried other pulsout values from 1 to 2000 just for the fun of it, but I keep getting the same result.
    The only thing I can think of is that the internal timer is in its LFINTOSC mode, which is 31kHz and would probably cause any pulse I care to send to look the same to the servo. There must be some language in PicBasic to tell the PIC to which frequency to set the internal oscillator, but I haven't been able to find it.
    What am I (still) doing wrong here?
    Post Datasheet !!!
    Hi,Eris
    Seems you have to read some closer the µChip Datasheet section 3 ...
    Lots ( ! ) of registers to set " by hand " that PbP do not handle !!!
    to confirm that, just program a dusty 16F84 ... will work properly with your example !!!
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
