Thanks elektroline, your VB allowed me to compare with what i had and the reason the serial data coming back was goofed was because of one of the setting in Comm1.
I'm still not convinced i have the PIC code right though, does this look right?
As i say, if i send a 1 from VB nothing if i send t1 or a1 or any letter followed by 1, then the LED flashes and the command is sent back to VB.
Cheers,Code:include "modedefs.bas" Clear DEFINE OSC 20 DEFINE LOADER_USED 1 ADCON1 = %00001111 In VAR PORTA.5 Out VAR PORTA.4 Loop Var Byte LED VAR PORTB.1 test var word test = 1 TRISB = %10000001 ' Set PORTB (0)INPUT (1-5)OUTPUTS Start: SERIN IN, N2400, [#TEST] IF TEST = 1 THEN GOSUB FLASH ENDIF write 3, test ' IF test = 1 THEN GOSUB FLASH pause 500 ' low PortB.1 read 3, test SEROUT out, N2400, ["That Worked ", #test + 5] ' Senda the wording "That Worked" and a number GOTO Start Flash: For loop = 1 to 5 LED = 1 Pause 100 LED = 0 Pause 100
