need help to set up a serial link
Results 1 to 9 of 9
    kinsiro's Avatar
    kinsiro Guest
    Default need help to set up a serial link
    hi, i m doing my fyp title serial link communication, now i m using pic16f84 as my controller, i connect my pic to RS232(MAX232CPE-the chip i use), then connect it to computer. now i m using the command as following
    __________________________________________________ ______________
    Include "modedefs.bas" 'to enable the mode option for n9600
    trisa = %00010
    TRISB = %00000000
    symbol sec = 1000
    d0 var byte
    s_out var porta.0 'set pin no as output pin
    s_in var porta.1 'set pin no as input pin
    led var portb.4
    loop:
    Serin s_in, n9600, 1000, no_data, ("x"), [d0]
    serout s_out, n9600, [d0]
    goto loop
    no_data:
    high led
    pause sec
    goto loop
    how come i dun c the led light and i dun get any data from the pic...
    p/s: how can i know whether my code is successfully sent? any idea to do tat?
    Aug 2005
    Default You need to set serin and serout to TRUE
    Try this.
    trisa = %00010
    TRISB = %00000000
    symbol sec = 1000
    d0 var byte
    led var portb.4
    loop:
    Serin s_in, T9600, 1000, no_data, ("x"), [d0]
    serout s_out, T9600, [d0]
    goto loop
    no_data:
    high led
    pause sec
    goto loop
    Sphere
    kinsiro's Avatar
    kinsiro Guest
    cannot oh.. the compile process is fail.. it stated error line-bad expression.. error line-expected '('
    why will it like this?
    Aug 2005
    Tried compiling the program and got the same errors. What do you want the program to do and what commands are you sending to the pic.
    Sphere.
    Ahem... people!!!!
    The compiler is telling you what the problem is... let's all go back and read the MANUAL as to the correct SYNTAX for SERIN...
    Not this...
    ...but this...
    Serin s_in, T9600, 1000, no_data, ["x"], d0
    There's even an example in the book - read it!
    Aug 2005
    Hi Melanie still new to all this serial stuff myself, I just thought I would try to help some with the limited knowledge I have gained. By the way what part of the world are you from.
    Sphere.
    I'm pretty cosmopolitan actually, but for the last few years London England (hub of the Universe) is my home.
    Aug 2005
    Thanks for the reply Melanie.From the UK myself. Maybe we meet accross a keyboard again.
    Sphere.
    kinsiro's Avatar
    kinsiro Guest
    Quote Originally Posted by Melanie
    Ahem... people!!!!
    Not this...
    ...but this...
    thx malenie.. and every1 i had done the rs232 part.. n comm is perfect
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 16th August 2009, 23:57
  2. Interruptus Frustratus
    Last Post: - 17th April 2009, 20:36
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
