Serial comm between two PICs
Results 1 to 25 of 25
    Oct 2013
    Default Re: Serial comm between two PICs
    Here are the codes of pic1 and pic2.Pic1 have the quartc on 8 MHz but I gave it a DEFINE OSC 4
    becouse the pic2 works at 4 MHz.I am shure that everything works in PIC1 exept DEBUG becouse I checkedout.I am shure that PIC2 is running becouse it puts the port-out signals in the right order and it change the PIC2 addresses 00,01,02,03 to zero values (00,00,00,00).PIC2 have an internal OSC and it works at 4 MHz and I can't measure it, but PIC1 works in 8 MHz but I guess it devides the 8MHZ becouse I wrote DEFINE OSC 4.I am wondering if the BAUDRATE is to fast or is the code of DEBUG correct?
    Not at all. That's not what DEFINE OSC does, look it up in the manual.
    Yes, the PIC is running at 8MHz but you're telling the compiler it's running at 4MHz. The compiler calculates the baudrate timings based on 4MHz when in reallity it's running twice as fast - the actual baudrate will be double what you tell it.
    Oct 2013
    Ahaa I will change PIC1 code to DEFINE OSC 8 and then I will let you know what will happen.Thanks.
  1. Pic to pic interrupt ans serial comm
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 10th May 2008, 22:43
  2. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 18:30
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 4th April 2004, 23:58
