Serial comm between two PICs
Results 1 to 25 of 25
    Default Re: Serial comm between two PICs
    It's hard to guess since you haven't posted the actual code you're using, missing variable declarations etc but "it doesn't work" is THE worst problem description you can ever give - of course "it doesn't work"... You wouldn't even be posting here in the first place if it did, right?
    So, What exactly doesn't work? How do expect it TO work? What have you done, except posting here, to try finding the issue?
    Are the sending PIC actually running? Is it running at the correct speed (4MHz)? Is it sending anything at all? Is the receiving PIC actually running? Is IT running at the correct speed (4MHz)?
    One thing, which doesn't really prevent it from "working" but may be fooling you, is that on the sending side the variable BROJ never changes, it's always zero (or perhaps there's more code that you didn't show).
    Oct 2013
    Here are the codes of pic1 and pic2.Pic1 have the quartc on 8 MHz but I gave it a DEFINE OSC 4
    becouse the pic2 works at 4 MHz.I am shure that everything works in PIC1 exept DEBUG becouse I checkedout.I am shure that PIC2 is running becouse it puts the port-out signals in the right order and it change the PIC2 addresses 00,01,02,03 to zero values (00,00,00,00).PIC2 have an internal OSC and it works at 4 MHz and I can't measure it, but PIC1 works in 8 MHz but I guess it devides the 8MHZ becouse I wrote DEFINE OSC 4.I am wondering if the BAUDRATE is to fast or is the code of DEBUG correct?
    Not at all. That's not what DEFINE OSC does, look it up in the manual.
    Yes, the PIC is running at 8MHz but you're telling the compiler it's running at 4MHz. The compiler calculates the baudrate timings based on 4MHz when in reallity it's running twice as fast - the actual baudrate will be double what you tell it.
    Oct 2013
    Ahaa I will change PIC1 code to DEFINE OSC 8 and then I will let you know what will happen.Thanks.
  1. Pic to pic interrupt ans serial comm
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 10th May 2008, 22:43
  2. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 18:30
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 4th April 2004, 23:58
