read signal from computer
Results 1 to 2 of 2
    menhwa's Avatar
    menhwa Guest
    Question read signal from computer
    i'm a beginner for using PBP, so i face some technical problem.
    as i wanna to receive data from computer, is it i just need to use the command of "serin"? then do the PIC will keep detecting the data into the PIC from computer? since i cannot found the function of timer in PBP.
    hope that someone can help me...
    Feb 2005
    Kolkata-India
    Default POST your exact system design requirements
    If you do not elaborate your question it is very difficult to answer. The Serin command is a software driver serial TX/RX routine. So until and unless you are doing it often you may miss some data. A faster approach is to use to CTS, RTS lines on your ports by which you can control the handshaking by the PIC itself. Some PICs feature a hardware UART, which makes your life a little easier. So we need the PIC you are using and the intention of your program.
    Sougata
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. PBP code to read R/C signal from receiver
    Last Post: - 28th October 2009, 21:51
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
