Micro code studio free?
Results 1 to 9 of 9
    PBP now ships with the free version of MicroCode Studio. This is the same free version you can download.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Are there any limitations I should be concerned with?
    Thanks.
    The big difference with free version is the limitation on ICD support. This should all be in the help file.
    -Bruce
    tech at rentron.com
    I don't know what I've done wrong but...
    (A) Micro code studio "can't locate" the programmer
    Everything is setup fine, parallel port, default programmer is EPIC.
    (B) So I tried just pulling up the programmer software on it's own and loading a known good hex file and I get...
    "unable to access driver"
    (C) the regulator with 13volts on it is hotter than hell
    (D) the only mistake I made was accidently put a 40 pin 16c65b in backwards. This epic programmer actually has 2 DIFFERENT PIN 1 situations....that is an accident waiting to happen.
    and also, I'm not getting anything out of the other regulator (5v)?
    The wall transformer they sent (Jameco) has a raw 20vdc on it disconnected.
    Check that....the 5V supply is fine....but still same problems
    damn....had it on the wrong header for the 8-40 zif socket.
    hope nothing was damaged.
    Micro code was looking for Epicwin but Meprog is what it needed.
    Programmer survived....this zif adapter is horse****.
  1. HARDWARE I2C SAMPLE CODE question
  2. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  3. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  5. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 21:17
