string&i2c
Results 1 to 5 of 5
Thread: string&i2c
    cesurcelik's Avatar
    cesurcelik Guest
    Default string&i2c
    hi all.
    what i want to do is sending string from pc-hyperterminal via pic16f876 to i2c then reading i2c
    my code is:
    INCLUDE "MODEDEFS.BAS"
    DEFINE CHAR_PACING 65000
    DEFINE OSC 20
    CONTROL CON $A0
    DPIN VAR PORTC.4
    CPIN VAR PORTC.3
    VALUE VAR BYTE[21]
    ADDRESS VAR BYTE
    SERIN2 PORTC.7,396,[WAIT("Ee"),STR VALUE \ 21]
    ADDRESS=0
    WRITEX:
    FOR ADDRESS=0 TO 20
    I2CWRITE DPIN,CPIN,CONTROL,ADDRESS,[VALUE]
    PAUSE 10
    NEXT ADDRESS
    READX:
    FOR ADDRESS=0 TO 20
    I2CREAD DPIN,CPIN,CONTROL,ADDRESS,[VALUE]
    SEROUT2 PORTC.6,396,[#ADDRESS,"=",VALUE[ADDRESS],10,13]
    NEXT ADDRESS
    LOOP:
    GOTO LOOP
    when i send "EeABCDEFGHIJKLMNPRSTUV" to i2c
    the response is:
    Òú
    1:B
    2:C
    3
    4:E
    5:F
    6:G
    7:H
    8:I
    9:J
    10:K
    11:L
    12:M
    13:N
    14:P
    15:R
    16:S
    17:T
    18:U
    19:V
    20:
    as you see the ,i can't read the first address and value(0=A),i don't understand why?
    tank you
    beto's Avatar
    beto Guest
    May be Your write Routine, test this:
    WriteX
    FOR ADDRESS=0 TO 20
    I2CWRITE DPIN,CPIN,CONTROL,ADDRESS,VALUE[ADDRESS]
    PAUSE 10
    NEXT ADDRESS
    cesurcelik's Avatar
    cesurcelik Guest
    @beto
    tanks for quick response.
    i've alredy tryed what you said.but the responce is
    êú
    1=B
    2=C
    3=D
    4=E
    5=F
    6=G
    7=H
    8=I
    9=J
    10=K
    11=L
    12=M
    13=N
    14=P
    15=R
    16=S
    17=T
    18=U
    19=V
    20=
    there is no change
    beto's Avatar
    beto Guest
    You are using level shifters?, the problem then looks as voltage chirp, if you is using only resistors then try to set High the TX pin BEFORE Data transmition!
    cesurcelik's Avatar
    cesurcelik Guest
    @beto
    thanks again
    i did it as you said
    now the response is:
    0=ÿ
    1=B
    2=C
    3=D
    4=E
    5=F
    6=G
    7=H
    8=I
    9=J
    10=K
    11=L
    12=M
    13=N
    14=P
    15=R
    16=S
    17=T
    18=U
    19=V
    20=
    i can see first address but not correct value
