Real Time Clock & Eeprom
Results 1 to 9 of 9
    Question Real Time Clock & Eeprom
    hello for all
    first sorry for my bad english
    i hope i find spme help for this proplem
    the problem :
    1:i'm newby in picbasic
    first i have a table in eeprom with a bout five specific times for 30 day
    so i want to check the table every 1 minute
    when the two times identical turn on a buzzer
    this project for islamic prayer
    if you have any another idea tell me
    thanks for any help
    again sorry for bad english
    can u give me any examples
    Is it the same time each day? Out of curiosity what are the times?
    Is it the same time for each day of the week?
    Is it the same time for every day of the year?
    What happens during Daylight Savings period when the clocks move an hour forwards or backwards... does the prayer time also move or does it stay constant with Universal Time?
    Talking thanks alot
    in the name of god
    first of all thank u very much for high speed response
    i'm realy wonderfull
    any way
    of course the times are not constant
    there r an accurate equations for those calculations but they r difficult
    but as i know it's hard to implemnted in PIC
    so i decided to store for now a table for one month "wich already calculated"
    if this idea succes i will contune with all the year
    the times as following "only examples "
    fajer noon after noon sunset after sunset"isha"
    e.g 6:10 12:15 16:15 19:20 20:13
    6:11 12:16 .................................................
    again thanks for any help
    now i agree at least with this
    but if u want help me to make a universal clock for all the world
    i will send all the equations for u
    thansssssssssssssssssssssss very mush Melanie
    i'm online now for any other questions
    Jan 2006
    Istanbul
    Cool How to Calculate Islamic Prayer Times
    The following equations may be used to calculate the prayer times; copied from a WEB site which I do not remember from where. I still could not figure out how it generates the times.
    One should know a little about the Islamic Prayer times to understand the concept behind these calculations. Basicly, Islamic Prayer times are location and date specific. A calculator for general use must have a location input and a date input. Location should be in terms of meridian and parallel of a city (for instance). The calculator then calculates the sun's movement based on the location and the date entered by the user; and then generates the prayer time. The time pattern is quite complex but of course there is a logic behind it.
    Here is the calculation:
    (R-L) T
    Z = 12+ ----- + --- ........1
    15 60
    1 {sin(-0.8333-0.0347(H)^0.5)}-sinD.sinB
    U= -- arccos -------------------------------------- ........2
    15 cosD.cosB
    1 -sinG-sinD.sinB
    V= -- arccos --------------- ........3
    15 cosD.cosB
    1 sin{arccot(1+tan(B-D)}-sinD.sinB
    W= -- arccos -------------------------------- ........4
    15 cosD.cosB
    1 sin{arccot(2+tan(B-D)}-sinD.sinB
    X= -- arccos -------------------------------- ........5
    15 cosD.cosB
    where
    B= latitude of place
    L= longitude of place
    R= reference longitude (i.e. TIME BAND x 15)
    H= height above sea level in metres
    D= declination angle of sun from celestial equator (-ve in southern hemisphere)
    T= equation of time
    G= twilight angle
    'Names of prayer times:
    Fajr = Z-V
    Sunrise = Z-U
    Zuhr = Z
    Asr1 (Shafi) = Z+W
    Asr2 (Hanafi) = Z+X
    Maghrib/Sunset = Z+U
    Isha = Z+V
    The algorithms to calculate T and D are not shown here. These algorithms may be found in, for example, Jean Meeus' Astronomical Algorithms. Zuhr time is calculated using equation 1. The time for sunrise and sunset/ maghrib may be calculated by subtracting or adding 'U'(obtained from equation 2) to the Zuhr time respectively.
    Fajr and Isha times may be calculated by subtracting or adding 'V' (obtained from equation 3) to the Zuhr time respectively. The term G (twilight angle) in equation 3 is usually set to 18 degrees. For a location with an extreme latitude, days in summer may be so long that twilight persists between sunset and the next sunrise. Under these circumstances, 'V' is undefined and Fajr and Isha have to be determined using agreed principles of fiqh.
    The start of Asr time (Shafi) may be obtained by adding 'W' (obtained from equation 4) to Zuhr; Asr time (Hanafi) is calculated by adding 'X' (obtained from equation 5) to Zuhr.
    ----------------------------end of post------------------------------
    Jan 2006
    Istanbul
    Cool Islamic Prayer Times - lookup table
    Also, for smart_storm's problem, described above, an example can be as below.
    Example: Starting from today,16.02.2006, prayer time table for the next 30 days for location: Los Angeles/USA is as below (actual times). Let say these times and dates are in an eeprom.
    (six times instead of five times are given)
    Date-----Time1,Time2,Time3,Time4,Time5,Time6
    16.02.2006 5 08 6 32 12 14 15 17 17 44 18 58
    17.02.2006 5 07 6 31 12 14 15 17 17 45 18 59
    18.02.2006 5 06 6 30 12 14 15 18 17 46 19 00
    19.02.2006 5 05 6 29 12 14 15 19 17 46 19 00
    20.02.2006 5 04 6 28 12 14 15 19 17 47 19 01
    21.02.2006 5 03 6 27 12 14 15 20 17 48 19 02
    22.02.2006 5 02 6 26 12 14 15 20 17 49 19 03
    23.02.2006 5 01 6 25 12 13 15 21 17 50 19 04
    24.02.2006 5 00 6 23 12 13 15 22 17 51 19 04
    25.02.2006 4 59 6 22 12 13 15 22 17 52 19 05
    26.02.2006 4 58 6 21 12 13 15 23 17 53 19 06
    27.02.2006 4 57 6 20 12 13 15 23 17 54 19 07
    28.02.2006 4 55 6 19 12 13 15 24 17 54 19 08
    01.03.2006 4 54 6 17 12 12 15 24 17 55 19 09
    02.03.2006 4 53 6 16 12 12 15 25 17 56 19 09
    03.03.2006 4 52 6 15 12 12 15 25 17 57 19 10
    04.03.2006 4 50 6 14 12 12 15 26 17 58 19 11
    05.03.2006 4 49 6 12 12 12 15 26 17 59 19 12
    06.03.2006 4 48 6 11 12 11 15 27 17 59 19 13
    07.03.2006 4 47 6 10 12 11 15 27 18 00 19 13
    08.03.2006 4 45 6 09 12 11 15 27 18 01 19 14
    09.03.2006 4 44 6 07 12 11 15 28 18 02 19 15
    10.03.2006 4 43 6 06 12 10 15 28 18 03 19 16
    11.03.2006 4 41 6 05 12 10 15 29 18 04 19 17
    12.03.2006 4 40 6 03 12 10 15 29 18 04 19 18
    13.03.2006 4 39 6 02 12 10 15 29 18 05 19 18
    14.03.2006 4 37 6 01 12 09 15 30 18 06 19 19
    15.03.2006 4 36 5 59 12 09 15 30 18 07 19 20
    16.03.2006 4 35 5 58 12 09 15 30 18 08 19 21
    17.03.2006 4 33 5 57 12 09 15 31 18 08 19 22
    If you check the table carefully, minutes sometime shift for 2 and 3 minutes; not for one minute everyday; or they do not change for two-three days. Lets not think about this part much, unlike the previous post, as they will be prepared to be read.
    Given the table, smart_storm can write a clock code and match the hour and minute with the lookup table from eeprom.
    For instance, on date 16.02.2006, Time1=5:08 (actualy 05:08 morning time) so that we can store this in time1 and time1x variables as 05 and 08 respectively.
    Time1 holds the hour and time1x holds the minute from eeprom lookup table.
    If we also use an RTC chip such as DS1302 for instance, and hold the hour and minute in variables DShour and DSminute then we can come up with a sample concept as below.
    DShour var byte 'variable: hour from DS1302
    DSminute var byte 'variable: minute from DS1302
    time1 var byte ' variable: one of six times in a day to store hour from eeprom lookup table.
    time1x var byte 'variable: the sister variable of time1 variable to store the minute from eeprom lookup table.
    time2 var byte 'other time etc..
    time2x var byte '...etc
    .....etc.
    loop:
    gosub read_ds1302 'codes for reading DS1302...
    gosub read_eeprom 'codes for reading eeprom lookup table....
    gosub do_convertion 'HEX and DEC convertions are done...
    If DShour=time1 AND DSminute=time1x then GOSUB buzzer 'to match the time from DS1302 with the time from eeprom, and ifthey match buzz the buzzer.
    goto loop
    Hope this post and the previous one can help people write a code for prayer times.
    Question thanks alot
    MR. sayzer
    i don't know how i can thank u for great explanation
    both in first and second posts
    so i said using equations solve all the problems
    but it's very difficult not only in PIC but also using PC
    so let's stay at the table solution
    for now i hope MELANIE understand the problem
    as for MR.sayzer when i said 1 min this is because this ensure
    that two times will identical at some time
    because the change is in minutes
    so i hope that some one can help
    excuse me but if there is no problem please don't use the RTC DS1302
    or any other RTC because in our country we can't find those real time clocks
    so i Prefer the programming solution for the clock
    another thing you are talking with PICBASIC beginer
    this is as for me
    i hope mr.sayzer still with us to help
    thanks for this special forum
  1. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 04:52
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 16:05
  4. Real Time Clock
    Last Post: - 8th December 2006, 02:02
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 21:56
