I don't think the v.2.43 PBP assembler is capable of accessing config words at addresses other than 2007h, this could be an oversight by MeLabs... and this is perhaps one of the reasons why you're forced to use MPASM with the 18F series...
I can see only two options at this time...
1. Use MPASM Assembler instead of PM adjusting the defines accordingly.
2. Manually override those two settings in your programmer at program time.
Both of those should keep you going, but I don't think you'll end up getting a fix for this to V2.43.
Melanie
