Could any pro out there help me to solve it? really appreciates
Results 1 to 2 of 2
    Mar 2007
    Default Could any pro out there help me to solve it? really appreciates
    i have this problem on my program. I tried calling the interrupt routine but it just won't be called. For this case, i need to press the SW3(button) and there will be an interrupt but the interrupt just wont be activated and hence the routine won't be called. Can anyone help me with this? Any help will be appreciated.My source code is as below:
    #include<p18f4620.h> //for special function register declarations
    #include<portb.h> //for the RB0/INT0 interrupt
    //#include<adc.h>
    //#include<stdlib.h>
    //#include<delays.h>
    void Record (void);
    #pragma code InterruptVectorHigh = 0x08
    void InterruptVectorHigh(void)
    _asm
    goto Record
    _endasm
    #pragma code //allow the linker to locate the remaining code
    #pragma interrupt Record
    void Record(void)
    PORTDbits.RD6=0;
    PORTDbits.RD7=0;
    PORTCbits.RC2=0;
    INTCONbits.INT0IF=0; //clear flag to avoid another interrupt
    void EnableHighInterrupts(void)
    RCONbits.IPEN =1; //enable interrupt priority levels
    INTCONbits.GIEH=1; //enable all high priority interrupts
    void WaitForRecord(void)
    //INTCONbits.RBIF=0;
    while(1); //wait for the SW3 button to be pressed
    void main(void)
    /*Port, TRIS and LAT initialisation*/
    //TRISA = 0x8F; //RA<3:0> as inputs, this value will change after
    //checking PORT A
    //PORTAbits.RA4=1;
    //PORTAbits.RA5=1; //it showed HIGH on hardware but not at the
    //watch view
    ADCON1 = 0x0F;
    TRISB = 0x07; //RB<2:0> as inputs
    //RB<5:3> as outputs
    //RB<7:6> as inputs
    LATB = 0x00;
    //PORTB=0x00;
    //PORTBbits.RB3=1;
    //PORTBbits.RB4=1;
    //PORTBbits.RB5=1;
    //TRISC = 0x20; //RC5 as inputs
    //RC<7:6>, RC<4:0> as outputs
    //PORTCbits.RC0=1;
    //PORTCbits.RC1=1;
    //PORTCbits.RC2=1;
    //PORTCbits.RC3=1;
    //PORTCbits.RC4=1;
    //TRISD = 0x00; //RD<7:0> as outputs
    //PORTDbits.RD6=1;
    //PORTDbits.RD7=1;
    //TRISE = 0xB0; //RE<2:0> as outputs, this value will change after
    //checking PORT E
    //ADCON1 = 0x0A;//Configure A/D for digital inputs for PORT E
    //PORTEbits.RE0=1;
    //PORTEbits.RE1=1;
    //PORTEbits.RE2=1;
    EnableHighInterrupts();
    OpenRB0INT(PORTB_CHANGE_INT_ON & //enable the RB0/INT0 interrupt
    PORTB_PULLUPS_ON & //configure the RB0 pin for input
    FALLING_EDGE_INT); //trigger interrupt upon SW3 button
    //depression
    WaitForRecord();
    And yet again...look at the top of the web page...and tell me what you see.
    I'd bet anything you'd see something relating to PicBasic.
    I'd bet twice anything you don't see anything relating to C.
    I could be wrong....
  1. PicBasic Pro Demo
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 20:10
  2. Calculate Byte Value Checksum in PBP Pro
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 8th July 2009, 23:50
  3. pbp pro versus oshon or bascom basic
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2006, 01:49
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. Need help converting to PB Pro from Mbasic Pro
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 11th February 2004, 08:43
