Tcpip
Results 1 to 7 of 7
Thread: Tcpip
    Dec 2005
    Lantronix xPort is about $50 US. They have virtual comm port software which will let you send & receive with the xPort module using serial methods.
    Mar 2005
    Iowa, USA
    I've been playing around with the Rabbit RCM3710 and the development kit HERE. It's programmable in C, but pretty easy to catch on to.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Mar 2004
    Thanks Rhino, that is the sort of thing that I am looking for (much better to lern as well than to plug in a box). Have you had any problems or found anything that I should be aware of before buying one of these kits. Once this has been mastered what do you need to make a working web server(other than programming time).
    Mar 2004
    Default Using Pic
    Can this be done on a pic?
    Mar 2005
    Iowa, USA
    Quote Originally Posted by Darrenmac
    I've just played around with it in my free time.... which isn't very often. I'd like to get back into it. There is quite a bit of source code available to demonstrate how to utilize the webserver, i/o, and email capabilities of the module. I figured if I'd use a pic to gather info from sensors, then send the data over the usart to the rabbit to store and show on the webserver.
    Ryan Miller
    Mar 2004
    Just found a book on Amazon called TCP/IP Lean. It teaches tcp/ip for embedded systems like pic's. Has anyone found any thing like this that is a free download?
