local variables
Results 1 to 3 of 3
Thread: local variables
    Hangover, Germany
    Default local variables
    I wish to use local variables...
    There must be a structure to mark parts of code to use local variables. It must be possible to use the same variable-name in different subroutines without using the same ram-location.
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    Hangover, Germany
    Talking
    Hey ... wasup ???? sleeping ????
    I think local variables are easy to implement !
    like:
    startlocal I
    (by now, the compiler adds a incrementing number to the variable, here it will be feg: loc_I_1)
    endlocal I
    (...it is lost...)
    The compiler has a seperat RAM-Locationlist for all this local variables and they are used like a stack... If Var1, var2 and var3 are used, var3 may be cleared, so var4 gets the same adress as var3...
    This will not be the best, but I think it is a first way...
    New England
    Yikes! - I know that if I used the same variable name, but different subs changed different RAM locations, I'd get hopelessly lost in writing any code at all!
  1. Internet-Ethernet and Local Net
    By Ioannis in forum General
    Last Post: - 7th January 2008, 22:16
  2. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  3. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
  4. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 22:00
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 19:37
