info string
Results 1 to 3 of 3
Thread: info string
    Dec 2005
    Default info string
    I wanted to know the meaning of the symbols of these two instructions:
    clrf TRISB ^ 0x080
    the symbol that is between trisb and 0x080.
    movwf TRISB & 7FH
    the symbol & followed by the hex 7fh that purpose has. Me if I have to plan the port in input or output I use only the binary notation or hex. And this 7Fh would have written it how binary: 01111111
    thanks
    chip20
    ^ is for a bitwise EXCLUSIVE OR
    & is for a bitwise AND
    chip... if you haven't already guessed, this is a forum for MeLabs PICBasic compilers... the answers to most of your Assembler questions will be found in the HELP files located in Microchips MPLab IDE. Go download it from the Microchip website - it's FREE.
    The answers to your questions above are found in detail in the MPLab Help file section "Expression Syntax and Operation" subsection "Arithmetic Operators and Precedence".
    Dec 2005
    Default Ok
    Ok Melanie. Thanks for the answers that you have given me. I follow your suggestion.
    Kiss
    by
    chip
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 03:16
  3. How to send a binary string on an output?
    Last Post: - 25th July 2007, 23:54
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
