LCD problem with 16F628
Results 1 to 26 of 26
Threaded View
  1. #14
    >"Melanie, You are tooo good !"
    Yup, that's what all the boys say!
    You may or may not like what I'll report...
    1. Taking your posted LCD_HEX file and burning a PIC16F628 with it produces all Black Squares just as you say. So here I confirm the same result. I do notice one anomaly - your HEX of the same program is twice the size of mine.
    2. But, taking your posted LCD_BAS file, renamed it LCD1, compiled it (with absolutely NO changes) with PBP2.46, burned the same PIC and it WORKS!!!! See appended picture. Try it with my HEX which I named LCD1.HEX.
    I used the compile line...
    PBP -p16F628 LCD1 -v
    Therefore, either...
    1. Your posted HEX file is not a true compilation of the posted BAS file...
    2. You are using a very old compiler which may have problems...
    3. Your compiler is corrupt...
    4. You are using some external IDE (such as MCS) which is causing you a problem.
    5. If you are compiling using Microchips MPASM the version you have may be old or corrupt.
    6. Or any other reason such as alien invasion of your neighbourhood...
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
