LCD problem with 16F628
Results 1 to 26 of 26
    Well, let's make sure your PIC is working...
    Got an LED? Connect it say between PortB.0 with a series Resistor (anything between 220R and 470R) and Vss (0v).
    After your LCD define put...
    LED var PORTB.0
    In your main loop, anywhere put...
    Toggle LED
    When the PIC runs, your LED should blink...
    Feb 2005
    GREECE
    Dear Melanie,
    You are right. My PIC is not working but I can not understand why?
    I try to blink a led but nothing.Where is the problem with my code?
    I attach my code and the hex file.
    PLEASE HELP MEEEEEEEEEEEEEEEEEEEEEEE.
    Feb 2005
    GREECE
    IS ALL THAT OK TO RUN MY PIC WITH INTERNAL OSC?
    I have to write DEFINE OSC 4?
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT ' system clock options
    @ DEVICE pic16F628, WDT_ON ' watchdog timer
    @ DEVICE pic16F628, PWRT_ON ' power-on timer
    @ DEVICE pic16F628, MCLR_OFF ' master clear options (internal)
    @ DEVICE pic16F628, BOD_ON ' brown-out detect
    @ DEVICE pic16F628, LVP_OFF ' low-voltage programming
    @ DEVICE pic16F628, CPD_OFF ' data memory code Protect
    @ DEVICE pic16F628, PROTECT_OFF ' program code protection
    There is no attachment... nail it to your posting and I will check it...
    Feb 2005
    GREECE
    HERE IT IS!!!
    Thanks Melanie
    Little busy this morning, but I'll breadboard a 16F628 later in the day with your code and let you know...
    n0oxv's Avatar
    n0oxv Guest
    Melanie,
    You are tooo good !
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
