LCD problem with 16F628
Results 1 to 26 of 26
    Jul 2008
    TURKIYE-KONYA
    Default Re: LCD problem with 16F628
    can you share your config settings?
    ;----[16F628A Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F628A"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSC_OSC_NOCLKOUT    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg&= _WDT_ON                 ; WDT enabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_OFF              ; RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD
    cfg&= _BODEN_ON               ; BOD enabled
    cfg&= _LVP_OFF                ; RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming
    cfg&= DATA_CP_OFF             ; Data memory code protection off
    cfg&= _CP_OFF                 ; Code protection off
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    Include "Modedefs.bas"
    PCON=%00001011 'set intosc to 4mhz
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    LCDOUT $FE, "SACDELI   "
    PAUSE 5000
    not suprised , it's certainly an odd use of the lcdout 254 directive
    Nice one Richard, don't know how I missed that!
    Haha thanks!
    Fixed it. But there were other issues too, MCU itself was also defective, replaced it, and everything works now just fine.
    All hardware 100% verified and working. But still no display
    I guess not then :-)
    It was working, but at certain moment, when swapping LCDs, I've applied power to MCU in reverse polarity LCD survived ,MCU - not.
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
