TMR1 interrupt question
Results 1 to 6 of 6
    Dec 2003
    Storrs, Ct.
    Talking Got it. The old disable interrupt trick.
    INTCON.7 = 0 before the section to be executed and
    INTCON.7 = 1 after the section to be executed worked fine
    Hi ronjodu,
    I'm glad you figured it out.
    The way I like to put it is ...
    The only problem with Interrupts, is that they Interrupt things.
    And, any statement that does it's timing in software (SerIn/Out, OWin/out, Debug, Freqout, Pulsin/out, etc) will have that timing disturbed by the interrupts. Synchronous commands like LCDOUT, I2C and ShifIn/Out don't care.
    Had you been using a paralel interface to the LCD, it wouldn't have a problem.
    However, As you've found out with Serout, 1 easy way is to just turn off GIE before those types of statements. But that can cause you to lose interrupts. I'm sure at some point you'll be doing more than just blinking lights, and the problem will become more evident.
    If you use the USART on the 16F876 with HSEROUT, then you won't need to turn off the interrupts while sending serial data, and you won't lose any interrupts.
    HTH,
      Darrel
    Dec 2003
    Storrs, Ct.
    Default Hserout
    I have tried the HSEROUT for the LCD and had trouble making it work. Serout2 was much easier to get working at the time. I guess I'll have to reinvestigate the HSEROUT option again.
    Is there an easy way for a beginner to tell which statements are affected by an interrupt and which are not. (trial and error perhaps?)
    These PBP statements will be affected by the use of interrupts.
    DEBUG/IN
    DTMFOUT
    FREQOUT
    NAP
    OWIN/OUT
    PAUSE/US
    POT
    PULSIN/OUT
    PWM
    RCTIME
    SERIN/OUT
    SLEEP
    SOUND
    WRITE
    WRITECODE
    XIN/OUT
    I think I got them all. If anyone sees one I missed, please chime in.
    Dec 2003
    Storrs, Ct.
    Default Thanks again
    Thanks again, I've included a note in my manual on each statement.
  1. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 20:12
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. USART interrupt not interrupting right
    Last Post: - 6th March 2005, 01:07
  5. Interrupt question
    By stone in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 23:11
