Do I have to use Table Reads & Writes to change the OSCSEN bit on a 18F452?
Results 1 to 6 of 6
    jessey's Avatar
    jessey Guest
    Default This is a great forum, thanks again Bruce.
    Hi Bruce,
    So using @__CONFIG _CONFIG1H, _OSCS_ON_1H & _XT_OSC_1H enables the Oscillator Switching Feature and starts my program off using the crystal that I have connected between OSC1 & OSC2 (pins 13 & 14). Then to switch to the 32 KHz crystal that I have connected between RC0/T1OSO & RC1/T1OSI (pins 15 & 16) I write T1CON.3=1 to set the T1OSCEN bit followed by another write OSCCONO.0=1 to set the SCS bit.
    Then at any time that I want to switch back to using the main oscillator again, all I have to do is to clear the SCS bit (OSCCONO.0=0). Thanks for that very useful information, now I can't wait until my 32 KHz crystal gets here so I can try it.
    Thanks Again
    jessey
    Hi Jessey,
    Yep. That's pretty much all there is to it.
    This enables osc switching in config word: _OSCS_ON_1H.
    T1CON.3 = 1 enables the Timer1 oscillator.
    OSCCON.0 = 1 switches from whatever external primary osc you're using to the one on Timer1.
    Switch to Timer1 osc: OSCCON.0 = 1
    Switch to main osc: OSCCON.0 = 0
    NOTE: Its not OSCCON0.0. It's OSCCON.0.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    jessey's Avatar
    jessey Guest
    Default How do I select the capacator values for the Timer1 crystal for LP mode?
    Hi Bruce,
    Yes I see that now (OSCCON0.0), a typo error, I didn't notice it when I posted. I'll have to be more diligent in the future.
    I thought that a friend of mine had a 32 KHz crystal that he was going to give me but when we searched for it, we couldn't find one. So now I'm in the process of ordering some from Digi-Key and I thought I'd check with you before I placed my order.
    In the manual it recommends a Epson C-001R32.768K-A crystal and then goes on to say that Microchip suggests 33 pF as a starting point in validating the oscillator circuit for the Epson crystal. The manual also goes on to state that since each resonator/crystal has its own characteristics, the user should consult the resonator/crystal manufacturer for appropriate values of external components.
    Since the appropriate recommended value from the manufacturer for the external capacitors is just a starting point then (if you've had any experience in this) what values of capacitors should I be ordering to compliment a crystal that the manufacturer has recommended a 12.5 pf caps for? Should I be purchasing several values above and below the recommended value, so I'll have them on hand, being that the initial recommended value is just a starting point? And how would I decide on what value would be best suited for my application?
    jessey
    Hi Jessey,
    Just use whatever cap values are specified by the manufacturer of the crystal.
    I've been using the SE3201 32kHz cylinder type with 12.5pF caps for years and it's rock solid. Never had any start-up or accuracy problems with them.
    I've got a whole box of them on-hand. Drop me an email with your shipping address, and I'll toss a couple SE3201 with caps in an envelope for you. No charge if you don't mind snail-mail..;o}
    -Bruce
    tech at rentron.com
    Last Post: - 14th June 2016, 07:55
  2. Doubt with interrupt on change
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 15:22
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 10:31
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
