PBP File Extension: .BAS vs .PBP
Results 1 to 5 of 5
    Aug 2003
    Northern California
    Default PBP File Extension: .BAS vs .PBP
    Greetings,
    Are there any differences or consideratons regarding files generated with a .BAS extension verses files with a .PBP extension using PicBasicPro(2.46)?
    Ned
    Feb 2005
    Kolkata-India
    Default Virtually not.
    If you open up the files in a text editor you will find virtually no difference. If you have other basic compilers installed double clicking on a bas file may open up that.So using a .pbp extension ensures that you open up microcode studio clicking on them.
    Sougata
    Aug 2003
    Northern California
    Default Thanks
    I suspected that there was not a difference, however, I did not want to over look anything.
    Ned
    Wink pbp vs bas ...
    Hi guys,
    As I am an old grumphy one, I still write small ( ? ) programs in GWBasic ... which default extension is ... .Bas !!!
    So, trying to open "PbP" source w/ dble click file gives a black screen and the " Direct file statement " warning ...
    and SYSTEM is required to go back to WINsmurf applications ...
    Aug 2003
    Northern California
    Default Earlier Basics
    Greetings Alain,
    There can be a definite advantage to extended Basic, GW Basic and Visual Basic for DOS for quick tasks without the overhead of the Windows based programming languages.
    Any of the DOS Basics really fly when running DOS on a Pentium class computer.
    Have you tried FreeDOS which is free:
    http://www.freedos.org/
    Ned
  1. PBP List file???
    By MOUNTAIN747 in forum General
    Last Post: - 28th February 2010, 19:48
  2. hex file inside PBP program for bootloading slave chips
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 10:47
  3. asm.lst file in PBP
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 11:30
  4. How to specify target in PBP file?
    By Jerson in forum mel PIC BASIC Pro
    Last Post: - 27th April 2008, 21:35
  5. convert .HEX file to .ASM or .BAS file ???
    By iugmoh in forum General
    Last Post: - 31st March 2008, 19:19
