Burning CONFIG fuses
Results 1 to 2 of 2
    hamster's Avatar
    hamster Guest
    Default Burning CONFIG fuses
    Hi. I want to burn the config fuse on a PIC without disturbing the program data. How to I setup the programmer options to do this?
    (I'm trying to set the code protection on an already programmed PIC)
    Hamster
    Without knowing what programmer software you're using it's impossible to answer. On my part, the elnec software allows you to do this... but if you haven't got an elnec (or compatible) programmer that answer will be of no use to you.
  1. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  2. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  3. 18F Config fuses
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 15:59
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
