8 Characters only on 16x1 LCD
Results 1 to 5 of 5
    Jan 2006
    Default 8 Characters only on 16x1 LCD
    Let me know if I am flooding the forum too much with my questions.
    I already had a previous post regarding LCD problems. I was finally able to get the LCD to show my characters, but its a 16x1 and only 8 characters work. Also, if I turn up the contrast, it only shows 8 blocks. I have read that they consider the 16x1 a 8x2, so I have tried skipping to the next line and continuing the word, but I have yet to succeed.
    Any suggestions?
    -brian
    Hi Doc,
    With only 16 posts so far, I think you've got a long way to go before it's too much. And, asking questions is what the forum's here for.
    As for the LCD. Since it's actually a 2 line by 8 char display
    did you include this define?
    DEFINE LCD_LINES 2 ' Number of lines on LCD
    Jan 2006
    hahaha, see, I knew it was something in the programming
    is there a way to set a decimal size. Like my program has an up and down button, when you press it you get a value on the lcd from 0 to 255. Is there a way to make it always be 3 decimal places, like 004?
    cheers to you
    Sure can,
    Just use the DEC3 modifier for the LCDOUT command.
    Jan 2006
    solved my problem once again
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Cannot write whole 16 characters using 16x1 lcd
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 15:36
  5. LCD 16 characters inline: only first 8 work
    By Mugel in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 22:07
