picbasicpro with rotation
Results 1 to 3 of 3
    cesurcelik's Avatar
    cesurcelik Guest
    Default picbasicpro with rotation
    hi all.
    i want to rotate 48 bits data with picbasic pro,but i don't know how to do that.
    if someone helped me about it ,i'd appreciate it.
    thank you in advance.
    You might want to run this through the MPLAB simulator to see how it works.
       WordA  VAR WORD BANK0 SYSTEM
       WordB  VAR WORD BANK0 SYSTEM
       WordC  VAR WORD BANK0 SYSTEM
       Counts VAR BYTE BANK0 SYSTEM
       GOTO Main        ' jump to Main
       ' shifts bits left from WordA to WordB to WordC with highest bit
       ' in WordC being trashed.
    Rotate  macro
        rlf WordA,f     ; msb of lowbyte into carry
        rlf WordA+1,f   ; carry into lsb of highbyte, msb of highbyte into carry
        rlf WordB,f     ; carry into lsb of lowbyte, msb of lowbyte into carry
        rlf WordB+1,f   ; carry into lsb of highbyte, msb of highbyte into carry
        rlf WordC,f     ; carry into lsb of lowbyte, msb of lowbyte into carry
        rlf WordC+1,f   ; carry into lsb of highbyte, msb of highbyte into carry
        bcf STATUS,C    ; trash msb of WordC to prevent shifting into WordA lsb
        decfsz Counts,f ; decrement shift counter
        goto $-D'8'     ; keep shifting until Counts = 0
        ' starting 48-bit value = 1
        WordA = 1     ' load low word
        WordB = 0     ' load mid word
        WordC = 0     ' load high word
        Counts = 47   ' shift 48-bit value left by Counts
        @ Rotate      ' do it
        ' resulting 48-bit value = $800000000000
    Here:
        GOTO Here   ' sit & spin after test
    This can be expanded to work on any number of variables. The only real limitation is available RAM &
    PBP system variables.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    cesurcelik's Avatar
    cesurcelik Guest
    @bruce
    i thank you for your reply
    it works perfectly
    cesur
  1. 2D Matrix Rotation
    By Art in forum mel PIC BASIC Pro
    Last Post: - 16th February 2010, 13:34
  2. PIC-LCD3310 Pin Outs for PicBasic(pro)
    By douglas.mauro in forum mel PIC BASIC Pro
    Last Post: - 13th March 2009, 08:17
  3. Proton+ and PicBasicpro
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 9th November 2007, 08:58
  4. Encoder rotation calculation
    By Stefan in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 08:37
  5. mikrobasic to picbasicpro
    By nicolasronan in forum mel PIC BASIC Pro
    Last Post: - 6th September 2006, 23:34
