Serin Question
Results 1 to 4 of 4
Thread: Serin Question
    Feb 2003
    Default Line is tooooo loooooong !!!
    Quoting from the PBP manual....
    4.14. Line-extension Character
    The maximum number of characters that may appear on one PBP line is 256. Longer statements may be extended to the next line using the line-extension character (_) at the end of each line to be continued.
    Branch B0,[label0,label1,label2,_
    label3,label4]
    Your example is 352 characters so it never sees the closing bracket.
    I dont think there is any difference in execution speed between a statement with say 5 variable and 5 statements with a single variable.
    eg.
    lcdout "hello"
    lcdout "h"
    lcdout "e"
    lcdout "l"
    lcdout "l"
    lcdout "o"
    generates the following extract from the assembler
    LCDOUT?C 068h h
    LCDOUT?C 065h e
    LCDOUT?C 06Ch l
    LCDOUT?C 06Ch l
    LCDOUT?C 06Fh o
    LCDOUT?C 068h h
    LCDOUT?C 065h e
    LCDOUT?C 06Ch l
    LCDOUT?C 06Ch l
    LCDOUT?C 06Fh o
    Obviously in the above example it is a lot easier to enter "hello" than 5 separate lines. Using either the single statement or the 5 statements the code compiled to 123 bytes. Using both it was 138 bytes.
    Using your code, I personally find the second "temporary fix" verison to be far more readable and it would be even easier with just "one chunk of data" per statement line.
    That way you would also be able to add comments to each line to say what you are receiving and skipping so that when you come back to your code in a few months time you can instantly tell what you were thinking when you wrote it
    Keith
    www.diyha.co.uk
    www.kat5.tv
    eoasap's Avatar
    eoasap Guest
    Keith, thanks for such a quick answer on my question. i actually prefer the second (working) method, but i was just afraid of dropping bytes. great to know that's not the case though!
  1. serin question?
    By sachymo in forum General
    Last Post: - 27th July 2008, 10:04
  2. Simple question about Serin..
    By Donat in forum mel PIC BASIC Pro
    Last Post: - 12th March 2008, 16:26
  3. serin string question
    By Sam in forum Serial
    Last Post: - 2nd December 2006, 21:29
  4. Serin question
    Last Post: - 30th August 2006, 23:39
  5. 16f872. config ports and serin question.
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 20th July 2005, 03:03
