PIC16F877 & Serial Comms
Results 1 to 12 of 12
    G4LCH's Avatar
    G4LCH Guest
    Red face Debug
    The debug statement also gives garbage
    Mark
    Aug 2005
    With Serout you need to include this at the top of your code:
    Include "modedefs.bas"
    N2400 will invert the bits so you can just use a resistor straight onto the serial port.
    If you have a max232 then this inverts each bit and you want to send it in True T2400
    Sean.
    http://www.cncdudez.co.uk
    G4LCH's Avatar
    G4LCH Guest
    Smile Thanks Sean
    Sean As I said in my note I have the modedefs in there and it compiles 100%
    I have also tried it direct with 1k resistors and via an interface and i get garbage in all cases.
    Mark
    G4LCH's Avatar
    G4LCH Guest
    Unhappy Update
    With the debug command I have also tried to use 4800 Bps and both inverted and non inverted with no luck still garbage.
    Mark
    Aug 2005
    Mark you say you are using VB.
    Have you simply ran up hyperterminal, set the com port to 2400 8 n 1, hit retunr to open port and then looked for the data, this will illiminate another step if the data is clear and then it has to be the VB side of things.
    Sean.
    G4LCH's Avatar
    G4LCH Guest
    Smile Thanks
    I have used my own comms software, hyperterminal etc plus vb (gives me bit stream access) and nothing works.
    I have this nagging feeling that this is the comms port to be honest or rarther the wrong caps on teh max232cpe level converter I have built several of these and have used 20uf instead these are proper maxim devices as well
    but I have this feeling that it may be possible that the caps are wrong as the ICD does not connect either mmmmmm off to replace the caps I think.
    But I have also tried without the interface as well and get exactly the same datastream ... The operating system is irrelevent but I have used W2k and OS X I have windows 98 so I may give this a try, I also need to check the fifo buffers for the W2K box and see if these are not messing me up...
    The vaio machine I am using does not want to talk to some devices sometimes and maybe this is the root, of course it could be guess work as the Mac is rock solid.
    Mark
    G4LCH's Avatar
    G4LCH Guest
    Angry Further Information
    Its not the serial ports
    b var byte
    include "modedefs.bas"
    for b = 1 to 100
    SEROUT PORTB.6,T2400,[#b]
    next
    Counts as you would expect, on the pic simulator with the code complied for the F84 and simulator set for F84 works great, set compiler to 877 and simulator to the 877 it delivers garbage.
    This is telling me that there may be something wrong with my basic compiler
    in the include files ?????
    this should give 12345 etc but give junk with the 877 selected
    Mark
  1. Serial Comms through TX/RX pair jumbled
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 21:04
  2. Some comments on serial comms please.
    By muddy0409 in forum Schematics
    Last Post: - 15th June 2007, 09:53
  3. Replies: 8
    Last Post: - 17th January 2007, 19:18
  4. Serial Comms with PIC micros
    By carlsnilsson in forum mel PIC BASIC Pro
    Last Post: - 21st September 2006, 01:00
  5. Replies: 2
    Last Post: - 23rd July 2006, 08:16
