Pulsein issues...
Results 1 to 5 of 5
    Aug 2005
    NC, USA
    Default Pulsein issues...
    I am using a pulsin to read RC signals. I am using a 18F2220. It works fine with a HiTec Radio hooked up to it. I can't get it to work with a Futuba. I put the futuba and and hitec on the scope, they are exactly the same width, the only difference is the futuba is 3V peak, and the HiTec is 3.3. Theu are both above the threshold, right? It will work with the Futaba on port C3, A6, A7, and A5, not on port C2, C1, C0. I really need it to work on C2, C1, and C0, I already have board made and need to read 7 channels. It worked fine with the HiTec, but now I'm struggling with the Futuba.
    Wink
    Hi, Payne
    Do not use a schmitt trigger input or build a level adapter ...
    Aug 2005
    NC, USA
    OK. I jumpered to some spare TTL inputs and that seemed to fix it. It works pretty reliable on one of the Schmitt triggers. What if I just power the PIC with 3.3V, will that fix the issue?
    Talking
    I'd forgotten to suggest you !!!
    Funky Gibbon's Avatar
    Funky Gibbon Guest
    Are you using a pullup resistor on the input? the upper voltage doesn't really matter 3v, 3.3v ot 5v so long as you can get a definate logic high and logic low
    Shaun
  1. SERIN2 buffer issues...
    Last Post: - 16th October 2008, 03:49
  2. Solved: notes on annoying little issues
    By Probotics in forum mel PIC BASIC Pro
    Last Post: - 26th May 2008, 20:02
  3. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 21:41
  4. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 14:55
  5. pulsein question (units of measure?)
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th October 2007, 00:59
