Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Hi Bill,
    After looking at it and testing for a while, there was an error in most of my early includes files. I learned about the jumpover a little late. I compensated for this in my example programs, but it made it harder for others to use.
    For instance, in your LCD_3310v32.inc file, please change goto Start to goto OverLCD
    and at the very bottom of this include file, add this line: OverLCD:
    This fixed your code for me.
    Edit: and you should have _j or any other variable, but not _Variable as your variable. _Variable is used in the macro to get your variable. So use: PrintVar x,x, _j or something.
    Jun 2005
    West Australia
    Thumbs up All good now
    Hi Walter,
    That did the trick, thank you! Now if we can only get it to work on 16F chips... any takers?
    Regards to all,
    Bill
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
