Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Code is OK. May be you need a restart.
    Steve, the define is OK. It exists this too!
    Dec 2008
    Ploiesti, ROMANIA
    OK ! Thanks ! I just wait for the 16F648A...
    Dec 2008
    Ploiesti, ROMANIA
    I have the 648A. The code works just fine !
    ...but : I try to define anothers characters for display the temperature that I set ; the message is like in picture. How can I define anothers characters ?
    Thanks in advance !
    I found that I could add up to 6 more characters (30 more bytes) to your code without getting the same error. I don't know exactly why you are getting the stack overflow errors, but the eeprom space is very limited. Since you have so much more space with the 648a, you might think about storing all the character data in program memory. You would need to modify your code a little bit though. You can edit out the characters that you don't need to save a little space.
    FC var byte [5]
    Lcd_data var byte ' example Lcd_data = "I", gosub Lcd_SendChar , this will print the character "I"
    Lcd_SendChar:
        lookdown Lcd_data,[" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ"],CharNum'[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],CharNum
        Lcd_data = CharNum +32
        sELECT CASE lcd_data
        Case 32
        	FC(0)=$00:FC(1)=$00:FC(2)=$00:FC(3)=$00:FC(4)=$00 ' // sp
        Case 33
        	FC(0)=$00:FC(1)=$00:FC(2)=$2f:FC(3)=$00:FC(4)=$00 ' // !
        Case 34
        	FC(0)=$00:FC(1)=$07:FC(2)=$00:FC(3)=$07:FC(4)=$00 ' // " (use \)
        Case 35
        	FC(0)=$14:FC(1)=$7f:FC(2)=$14:FC(3)=$7f:FC(4)=$14 ' // #
        Case 36
        	FC(0)=$24:FC(1)=$2a:FC(2)=$7f:FC(3)=$2a:FC(4)=$12 ' // $
        Case 37
        	FC(0)=$c4:FC(1)=$c8:FC(2)=$10:FC(3)=$26:FC(4)=$46 ' // %
        Case 38
        	FC(0)=$36:FC(1)=$49:FC(2)=$55:FC(3)=$22:FC(4)=$50 ' // &
        Case 39
        	FC(0)=$00:FC(1)=$05:FC(2)=$03:FC(3)=$00:FC(4)=$00 ' // '
        Case 40
        	FC(0)=$00:FC(1)=$1c:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // (
        Case 41
        	FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$1c:FC(4)=$00 ' // )
        Case 42
        	FC(0)=$14:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$14 ' // *
        Case 43
        	FC(0)=$08:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$08 ' // +
        Case 44
        	FC(0)=$00:FC(1)=$00:FC(2)=$50:FC(3)=$30:FC(4)=$00 ' //
        Case 45
        	FC(0)=$10:FC(1)=$10:FC(2)=$10:FC(3)=$10:FC(4)=$10 ' // -
        Case 46
        	FC(0)=$00:FC(1)=$60:FC(2)=$60:FC(3)=$00:FC(4)=$00 ' // .
        Case 47
        	FC(0)=$20:FC(1)=$10:FC(2)=$08:FC(3)=$04:FC(4)=$02 ' // /
        Case 48
        	FC(0)=$3E:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$3E ' // 0
        Case 49
        	FC(0)=$00:FC(1)=$42:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // 1
        Case 50
        	FC(0)=$42:FC(1)=$61:FC(2)=$51:FC(3)=$49:FC(4)=$46 ' // 2
        Case 51
        	FC(0)=$21:FC(1)=$41:FC(2)=$45:FC(3)=$4B:FC(4)=$31 ' // 3
        Case 52
        	FC(0)=$18:FC(1)=$14:FC(2)=$12:FC(3)=$7F:FC(4)=$10 ' // 4
        Case 53
        	FC(0)=$27:FC(1)=$45:FC(2)=$45:FC(3)=$45:FC(4)=$39 ' // 5
        Case 54
        	FC(0)=$3C:FC(1)=$4A:FC(2)=$49:FC(3)=$49:FC(4)=$30 ' // 6
        Case 55
        	FC(0)=$01:FC(1)=$71:FC(2)=$09:FC(3)=$05:FC(4)=$03 ' // 7
        Case 56
        	FC(0)=$36:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // 8
        Case 57
        	FC(0)=$06:FC(1)=$49:FC(2)=$49:FC(3)=$29:FC(4)=$1E ' // 9
        Case 58
        	FC(0)=$00:FC(1)=$36:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // :
        Case 59
        	FC(0)=$00:FC(1)=$56:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // ";"
        Case 60
        	FC(0)=$08:FC(1)=$14:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // <
        Case 61
        	FC(0)=$14:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$14 ' // =
        Case 62
        	FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$14:FC(4)=$08 ' // >
        Case 63
        	FC(0)=$02:FC(1)=$01:FC(2)=$51:FC(3)=$09:FC(4)=$06 ' // ?
        Case 64
        	FC(0)=$32:FC(1)=$49:FC(2)=$59:FC(3)=$51:FC(4)=$3E ' // @
        Case 65
        	FC(0)=$7E:FC(1)=$11:FC(2)=$11:FC(3)=$11:FC(4)=$7E ' // A
        Case 66
        	FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // B
        Case 67
        	FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$22 ' // C
        Case 68
        	FC(0)=$7F:FC(1)=$41:FC(2)=$41:FC(3)=$22:FC(4)=$1C ' // D
        Case 69
        	FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$41 ' // E
        Case 70
        	FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$01 ' // F
        Case 71
        	FC(0)=$3E:FC(1)=$41:FC(2)=$49:FC(3)=$49:FC(4)=$7A ' // G
        Case 72
        	FC(0)=$7F:FC(1)=$08:FC(2)=$08:FC(3)=$08:FC(4)=$7F ' // H
        Case 73
        	FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$41:FC(4)=$00 ' // I
        Case 74
        	FC(0)=$20:FC(1)=$40:FC(2)=$41:FC(3)=$3F:FC(4)=$01 ' // J
        Case 75
        	FC(0)=$7F:FC(1)=$08:FC(2)=$14:FC(3)=$22:FC(4)=$41 ' // K
        Case 76
        	FC(0)=$7F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // L
        Case 77
        	FC(0)=$7F:FC(1)=$02:FC(2)=$0C:FC(3)=$02:FC(4)=$7F ' // M
        Case 78
        	FC(0)=$7F:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$7F ' // N
        Case 79
        	FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$3E ' // O
        Case 80
        	FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$06 ' // P
        Case 81
        	FC(0)=$3E:FC(1)=$41:FC(2)=$51:FC(3)=$21:FC(4)=$5E ' // Q
        Case 82
        	FC(0)=$7F:FC(1)=$09:FC(2)=$19:FC(3)=$29:FC(4)=$46 ' // R
        Case 83
        	FC(0)=$46:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$31 ' // S
        Case 84
        	FC(0)=$01:FC(1)=$01:FC(2)=$7F:FC(3)=$01:FC(4)=$01 ' // T
        Case 85
        	FC(0)=$3F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$3F ' // U
        Case 86
        	FC(0)=$1F:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1F ' // V
        Case 87
        	FC(0)=$3F:FC(1)=$40:FC(2)=$38:FC(3)=$40:FC(4)=$3F ' // W
        Case 88
        	FC(0)=$63:FC(1)=$14:FC(2)=$08:FC(3)=$14:FC(4)=$63 ' // X
        Case 89
        	FC(0)=$07:FC(1)=$08:FC(2)=$70:FC(3)=$08:FC(4)=$07 ' // Y
        Case 90
        	FC(0)=$61:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$43 ' // Z
    '    Case 91
    '    	FC(0)=$00:FC(1)=$7F:FC(2)=$41:FC(3)=$41:FC(4)=$00 ' // [
    '    Case 92
    '        FC(0)=$02:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$20 ' // \  (we are using this for " above)
    '    Case 93
    '    	FC(0)=$00:FC(1)=$41:FC(2)=$41:FC(3)=$7F:FC(4)=$00 ' // ]
    '    Case 94
    '    	FC(0)=$04:FC(1)=$02:FC(2)=$01:FC(3)=$02:FC(4)=$04 ' // ^
    '    Case 95
    '    	FC(0)=$40:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // _
    '    Case 96
    '    	FC(0)=$00:FC(1)=$01:FC(2)=$02:FC(3)=$04:FC(4)=$00 ' // '
    '    Case 97
    '    	FC(0)=$20:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$78 ' // a
    '    Case 98
    '    	FC(0)=$7F:FC(1)=$48:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // b
    '    Case 99
    '    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$20 ' // c
    '    Case 100
    '    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$48:FC(4)=$7F ' // d
    '    Case 101
    '    	FC(0)=$38:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$18 ' // e
    '    Case 102
    '    	FC(0)=$08:FC(1)=$7E:FC(2)=$09:FC(3)=$01:FC(4)=$02 ' // f
    '    Case 103
    '    	FC(0)=$0C:FC(1)=$52:FC(2)=$52:FC(3)=$52:FC(4)=$3E ' // g
    '    Case 104
    '    	FC(0)=$7F:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // h
    '    Case 105
    '    	FC(0)=$00:FC(1)=$44:FC(2)=$7D:FC(3)=$40:FC(4)=$00 ' // i
    '    Case 106
    '    	FC(0)=$20:FC(1)=$40:FC(2)=$44:FC(3)=$3D:FC(4)=$00 ' // j
    '    Case 107
    '    	FC(0)=$7F:FC(1)=$10:FC(2)=$28:FC(3)=$44:FC(4)=$00 ' // k
    '    Case 108
    '    	FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // l
    '    Case 109
    '    	FC(0)=$7C:FC(1)=$04:FC(2)=$18:FC(3)=$04:FC(4)=$78 ' // m
    '    Case 110
    '    	FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // n
    '    Case 111
    '    	FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // o
    '    Case 112
    '    	FC(0)=$7C:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$08 ' // p
    '    Case 113
    '    	FC(0)=$08:FC(1)=$14:FC(2)=$14:FC(3)=$18:FC(4)=$7C ' // q
    '    Case 114
    '    	FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$08 ' // r
    '    Case 115
    '    	FC(0)=$48:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$20 ' // s
    '    Case 116
    '    	FC(0)=$04:FC(1)=$3F:FC(2)=$44:FC(3)=$40:FC(4)=$20 ' // t
    '    Case 117
    '    	FC(0)=$3C:FC(1)=$40:FC(2)=$40:FC(3)=$20:FC(4)=$7C ' // u
    '    Case 118
    '    	FC(0)=$1C:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1C ' // v
    '    Case 119
    '    	FC(0)=$3C:FC(1)=$40:FC(2)=$30:FC(3)=$40:FC(4)=$3C ' // w
    '    Case 120
    '    	FC(0)=$44:FC(1)=$28:FC(2)=$10:FC(3)=$28:FC(4)=$44 ' // x
    '    Case 121
    '    	FC(0)=$0C:FC(1)=$50:FC(2)=$50:FC(3)=$50:FC(4)=$3C ' // y
    '    Case 122
    '    	FC(0)=$44:FC(1)=$64:FC(2)=$54:FC(3)=$4C:FC(4)=$44 ' // z
    '    case 123
    '        FC(0)=$00:FC(1)=$08:FC(2)=$36:FC(3)=$41:FC(4)=$00'  // {
    '    case 124
    '        FC(0)=$00:FC(1)=$00:FC(2)=$7F:FC(3)=$00:FC(4)=$00 ' // |
    '    case 125
    '        FC(0)=$00:FC(1)=$41:FC(2)=$36:FC(3)=$08:FC(4)=$00'  // }
    '    case 126
    '        FC(0)=$10:FC(1)=$08:FC(2)=$08:FC(3)=$10:FC(4)=$08'  // ~
        end SELECT
    Write_LCD:
        High Lcd_DC
        SHiftOUT Lcd_SDO , Lcd_CLK , MSBFIRST, [ FC(0),FC(1),FC(2),FC(3),FC(4),$00 ]
        Low Lcd_DC
    For the whole include file, you can look at: http://www.picbasic.co.uk/forum/showpost.php?p=73728
    http://www.scalerobotics.com
    Ok, for some reason it works if you say DATA @10,some data here, then when you have gotten about half way through the eeprom, stop writting, then start writing again where you left off with DATA 128(or where ever you left off at),rest of your data here.
    Don't know why you can't do it like you originally tried, but PBP does not seem to like it.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for repply ! I will try both variants.
    With this :
    DATA @110,$7E,$11,$11,$11,$7E,_ ' 65 A 22
    $7F,$49,$49,$49,$36,_ ' 66 B 23
    $3E,$41,$41,$41,$22,_ ' 67 C 24
    $7F,$41,$41,$22,$1C,_ ' 68 D 25
    $7F,$49,$49,$49,$41,_ ' 69 E 26
    $7F,$09,$09,$09,$01,_ ' 70 F 27
    $3E,$41,$49,$49,$7A,_ ' 71 G 28 etc,etc...
    I have another 25 characters ...enough for me. THANK YOU !
    Dec 2008
    Ploiesti, ROMANIA
    This is final version. I try to implement the function of clock (like this : http://www.picbasic.co.uk/forum/show...ght=clock+code ) but, even the code works verry, verry fine alone, I can't put together with my thermo....If somebody can do this...All the best !
    Hi Bill,
    After looking at it and testing for a while, there was an error in most of my early includes files. I learned about the jumpover a little late. I compensated for this in my example programs, but it made it harder for others to use.
    For instance, in your LCD_3310v32.inc file, please change goto Start to goto OverLCD
    and at the very bottom of this include file, add this line: OverLCD:
    This fixed your code for me.
    Edit: and you should have _j or any other variable, but not _Variable as your variable. _Variable is used in the macro to get your variable. So use: PrintVar x,x, _j or something.
    Jun 2005
    West Australia
    Thumbs up All good now
    Hi Walter,
    That did the trick, thank you! Now if we can only get it to work on 16F chips... any takers?
    Regards to all,
    Bill
    Thanks Bill.
    I double checked the code I posted here: http://www.picbasic.co.uk/forum/cont...Nokia-3310-LCD, and it is working for me. I am using this hardware: http://www.picbasic.co.uk/forum/showthread.php?t=10820 running at 48mhz.
    You are using the right syntax, so I can't really find the problem.
    The PrintVar is how I am printing the word variables in this example: http://www.picbasic.co.uk/forum/cont...-axis-g-sensor
    You want to post your code, and I will see if if runs on my hardware? I don't have an easy way to change my hardware for the display.
    Jun 2005
    West Australia
    Hi Walter,
    Attached code for the 18F252 also an edited copy of your Include file - only a few small font changes but it's what I'm using so here it is.
    I tried using Variable in place of j but same result. I'm sure it is something simple but I can't see it...
    Thanks for your help,
    Bill
    Default $2.95 glcd
    The Nokia 3310 display just became available at Sparkfun for $2.95 each. Pretty good price for what it can do! You can check it out here http://www.sparkfun.com/commerce/pro...oducts_id=9924. Here is the wiki page about interfacing it, based on posts in this thread: http://www.picbasic.co.uk/forum/cont...Nokia-3310-LCD
    Jun 2005
    West Australia
    Default @ PrintVar x,y, _anyvariable - example? Having problems...
    Hi Walter,
    Great job on your macro for the Nokia 3310 LCD, so much so that I think I'll move across to using these instead of the 16x2 I've been using everywhere so far. Thank you.
    I'm not having much luck getting the @ PrintVar x,y, _anyvariable to work though. I declare a word variable in my main program (j var word), give it a value to test (j=12345) then
    @ PrintVar 0,4, _j
    but only random values print and only 2 or 3 characters. Weird.
    Can you perhaps show me a working section of how to do it please? I'm using PbP 2.60, 18F252.
    Thanks and regards,
    Bill
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
