Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by fratello View Post
    Tested with negative temperatures; bug fixed !
    I can't - insuficient memory ! - using design like in post #116 (borders & author name). How to free memory ? I think the code can be optimized...
    Hi Fratello,
    I tried to compile the file you put here. It did not give any error to me like what you said. The resultant files are appended in the zip file for ready reference.
    Sarma
    Dec 2008
    Ploiesti, ROMANIA
    The code is full functionaly ! The graphics it's disable... If try to improve the way that "look" the display, it is no more space in memory...I think the solution it's to 'up-grade' to another PIC, with bigger memory !
    Mar 2006
    Hyderabad (India)
    I feel if one could write straight in assembly language, it would be smaller, in size. my comments may not suite the site s it is meant for promoting BASIC
    Sarma
    I found out how to add variables to my macro, so now using the include file, you can print any variable to the lcd by using:
    @ PrintVar x,y, _anyvariablehere
    (instead of loading a specific variable , then using @ PrintVar that I had before). Small change, but I figured it might help someone.
    Here is the segment of the macro that is part of the lcd_3310v31 include file (attached).
    '@ PrintVar macro function
    'format should look like this: @ PrintVar x,y, _anyvariable
    PrintVar macro x, y, Variable ;input values from: @PrintVar 0,1, _any_variable
        local OverVar
        goto OverVar
    OverVar
        MOVE?CB  x, _PosX           ;move x from above statement to PosX
        MOVE?CB  y, _PosY           ;move y from above statement to PosY
        MOVE?WW  Variable, _VarData ;move variable in statement to VarData
        L?CALL   _VariableOut       ;call VariableOut function
    VariableOut:
        @ bcf _digits
        for n = 4 to 0 step -1        'cycles through all possible digts of number
            Gosub Lcd_GotoXY          'place character at position PosX and PosY
            Lcd_Data = (VarData dig n) + 48 'digit number n to character str format
            if Lcd_data = 48 and digits = 0 then SkipChar 'skip if first char is 0
            @ bsf _digits             ;show that one character has been printed
            gosub Lcd_SendChar        'print char to screen
            PosX = PosX + 6           'next x position for character
    SkipChar:
        next n
    http://www.scalerobotics.com
    Quote Originally Posted by mvs_sarma View Post
    Hi Sarma,
    Certainly well written assembly code should use less space than assembly generated by a high level compiler, it all boils down to cost. If you live where the cost of living is very low and software engineers are paid little, assembly may be the correct path. If you live where everything costs way too much and software engineers start out at $50,000 and go way up from there, it becomes very difficult to recover that cost by saving $0.15 on the wholesale cost of the PIC. One other consideration in both instances, if the engineer uses the high level compiler, the time saved will be used to engineer more products. So IMHO, the way to achieve best overall results is High Level compiler WITH assembly assists, I E . . . Darrels Instant interrupts for example. As for your comments . . . Your comments are welcome here. We all benefit by sharing our Ideas and opinions, and we can keep them after sharing or adopt new ones, I believe it was Albert Einstein who said, " all knowledge is trial and error", which is to say the things you are taught are the result of somebody's mistakes.
    Joe S.
    Dec 2008
    Ploiesti, ROMANIA
    Hi to all !
    Me again...with one new problem : I write the code attached, for 16F648A, because I want to display some graphics elements (see sus, rand 1, rand 2, rand 3, rand 4, jos) .But when I put the code in Microcode Studio I receive the message "Warn : Test_648.asm 790:[102] code crosses boundary @ 800h". I think the code it's too big; please give me some solution !!! I want that my display having one nice 'looking' and without the parts for graphics elements...What can I do ?
    Thanks in advance !
    That is just a warning that you are crossing a boundary. All is good. How many bytes does it say you are using the lower left of microcode studio?
    Dec 2008
    Ploiesti, ROMANIA
    This is what MicroCode Studio say :
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
