Hello Fratello,
I have been looking over your code for a while now. I have not found anything obvious to me, although there may be something obvious to others.
One thing I did notice, is that your MainLoop will cycle through modes 0, 1, and 2, even without any buttons being pressed. This is fine, but one thing you are doing in mode 2, and after mode 2, is writing to the eeprom. At 4 mhz, you will reach that 1,000,000 write cycles quicker than you think (have not calculated it, but if this is really going to be a thermostat, I assume it is going to be running for a while). A better way to do it would be to only write the targettemp, etc to the eeprom when targettemp is different than the eeprom value for targettemp (ie, it has been adjusted).
Seems like the next step is to see if the 16f628a even knows if the buttons have been pressed. Why not make a simple light an LED line inside some of your if then statements to verify the chip knows a button has been pressed? This could help point to the source of the problem.
Walter
