Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Dec 2007
    Finland
    Post
    Quote Originally Posted by fratello View Post
    Using the command "goto main" I have some results ; now the display show the correct temperature...but still remains some 'points'... (see foto). I try different code for LCD_Clear, but not results... Please, help me more ! Thanks in advance !
    Could you post your entire code here? At least I did not see where you write "TEMP:" to screen. Also at which point you do your LCD clear routine. Problem might be in that code area...
    At least you managed to get DS18B20 to work. That's positive!
    BR,
    -Gusse-
    Dec 2008
    Ploiesti, ROMANIA
    Sorry...mea culpa ! This is the full code !
    Dec 2007
    Finland
    Post
    You are not using "LCD_Clear:" routine anywhere, so you are not clearing the LCD at any phase.
    Add this before "Main:"
    call LCD_Clear
    If that doesn't help, try to replace manual LCD write commands with SHIFTOUT. Similar what you have in "LCD_ByteOut:"
    BR,
    -Gusse-
    Dec 2007
    Finland
    Post Correction to last post
    I meant this (below) instead of "CALL"
    GOSUB LCD_Clear
    Why you are using CALL, shouldn't those be GOSUB instead?
    BR,
    -Gusse-
    Dec 2008
    Ploiesti, ROMANIA
    YES !!!! That work ! THANK YOU !
    I have learning again one more thing. Thanks to You, all members of this great forum. I'm happy !
    Now, I want to make the next step : "up-grading" the schematic from here - http://www.picbasic.co.uk/forum/show...7&postcount=35 for using with N3310 display. I will keep You on line ! All the best !
    Dec 2008
    Ploiesti, ROMANIA
    Now my project it is in this stage - see photo 1. I ask -again, sorry ! - for help : how to make like in photo 2 ? I do not understand how 'advanced' to next line (I think because of my poor english... ). I read the N3310 display .pdf and many examples, but still don't understand... Can somebody explain to me, please ?
    Dec 2007
    Finland
    Post
    You want to have "Temp:" on Row0 and temperature reading on Row1? If this is the case then I recommend to use library from post #95.
    This is how you can move positions on screen.
    PosX=[X-axis pos]:PosY=[Y-axis pos]:Gosub Lcd_GotoXY
    1) Goto PosX=0 and Pos=0
    PosX=0:PosY=0:Gosub Lcd_GotoXY
    Then add LCD write routines to display "Temp:"
    2) calculate where you want to write on Row1.
    X-axis
    84 pixel, 6 pixel width per character = 16 character per line
    Temp: -> 5 character -> 5 * 6 pixel = 30 (start pixel for temp reading)
    PosX=30
    Y-axis
    48 pixel, 8 height per character = 6 character per column
    1st row = 0, 2nd = 1, ... 6th = 5
    PosY=1
    PosX=30:PosY=1:Gosub Lcd_GotoXY
    Then add LCD write routines to display temperature reading.
    To take library into use, insert this to your code and save & unzip-file Nokia_LCD_3310_7110.zip to same directory (or mod path).
    '----- LCD Setup -----
    include "LCD_3310.pbp"
    You might want to use also other library functions... it might easier your life...
    BR,
    -Gusse-
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
