Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Feb 2004
    Germany
    Crematory,
    Pleas read this thread from the beginning.
    There are several code examples and linlt to DataSheets etc.
    regards
    Ralph
    Dec 2006
    Default Can you help me about Nokia 3310 pin connection ?
    i could not tied the connection. Can you help me ?
    1-Vdd-------- 5V
    2-SCK--------Portb.4
    3-SDIN-------
    4-D/C--------Portb.6
    5-SCE--------
    6-GND--------GND
    7-Vop--------
    8-RES--------Portb.7
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
    1-Vdd-------- 5V
    3-SDIN-------PORTB.5
    5-SCE--------
    6-GND--------GND
    7-Vop--------
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
    Datasheet => http://www.myplace.nu/mp3/files/pcd8544.pdf
    http://www.picbasic.co.uk/forum/show...7&postcount=40
    Dec 2006
    Default 3310 Lcd
    Thanks for your tip. Lcd is working.
    Quote Originally Posted by pcbb View Post
    This wouldn't be the practically the same LCD as the one found at Sparkfun is it?
    http://www.sparkfun.com/commerce/pro...oducts_id=569#
    amro's Avatar
    amro Guest
    Question 6310 Lcd ?
    Hi all
    any body deal with Nokia 6310 LCD ?
    it is exist two opinion about this LCD :
    first it is operate by i2c protocol .
    the other operate by SPI 3-wire .
    which is true ?
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
