Using Nokia LCD
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Oct 2010
    Default Re: Using Nokia LCD
    i have fixed the circuit from that page and work fine.
    http://www.radiolocman.com/shem/sche....html?di=44132
    he is using the following
    LcdReg = %00100001 'LCD Extended Commands.
    call PrintCtrlLcd
    LcdReg = %10101001 'Set LCD Vop (Contrast).
    call PrintCtrlLcd
    LcdReg = %00000110 'Set Temp coefficent.
    call PrintCtrlLcd
    LcdReg = %00010011 'LCD bias mode 1:48.
    call PrintCtrlLcd
    LcdReg = %00100000 'LCD Standard Commands, Horizontal addressing mode.
    call PrintCtrlLcd
    that means that the HEX of the Vop is $A9.
    He is also says:
    If by any chance the contrast isn't to your liking, it can be changed during the programming of Pic12F629, in the program location D2h. the current value A9h is the one I use with my LCD and don't know it will be for other LCDs. The value can be set to anything between 80 h and FFh, 80 h being minimum contrast and FFh maximum.
    OK, I've finished the new Include/driver/wrapper thing here. I'll post it in the next days. Still have some improvement to do. No big changes, but probably easier to use, a tad more flexible too.
    You guys should love it
    Stay tunned!
    Oct 2010
    hi mister_e
    i'm looking forward to see it. Thanks.
    Smile Re: Using Nokia LCD
    Hi all,
    i've been looking at this topic for some time now.
    I managed to get an original 3310 display and made some tests.
    First i tried the INC solution but i got the "Truncated to code size" errors ( using 16F88 or 16F628A ).
    Tried some examples posted here ( always changing ports to my configuration ) with a blank screen.
    Tried the test file with big numbers and it worked.
    Then moved to a 18F2550 micro-controller and once again the INC solution did not worked ( just had some ! simbols all over the place ).
    The only solution i got was to use the INC file together with Gusse's sugestion on using "Gosub Lcd_SendChar" instead of "@ PrintStr" format.
    This way works like a charm!
    Do you guys know of an 18 pin chip that would work ( since it doesnt work with the 16Fs ) ?
    Or Steve ( Mister-e ) will have a fresh new solution that will work on more chips ?
    My solution should work with anything, at compile time it decide which macro to build/compile/use.
    It should even work with many 12F... with some limitations.
    Out of curiosity, which PIC didn't worked for you?
    Hi Steve
    I was using the 16F88
    Oct 2010
    i was trying to use pic16f628a.
    I have seen over the internet some others they succeed with pic12f629
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
