Using Nokia LCD - Page 3
Results 81 to 120 of 301
Thread: Using Nokia LCD
Threaded View
  1. #14
    Dec 2007
    Finland
    Post Nokia 3310 and 7110 LCD command libraries
    I don't know how many is still using old (monochrome) Nokia LCD displays, but I do.
    To make it easier to write code for both 3310 LCD (PDC8544) or variants (Nokia 8210...) and 7110 LCD (SED1565), I made a common command library for both LCD types. So you can use same commands in your program and only change display and link right library file (see attachement for more info). Of cource there are more pixels in 7110 and therefore you must do some fine tuning for character/picture positions, but anyway it will work with a minimum effort. At least I hope so.
    I use this by including it to main program
    '----- LCD Setup -----
    include "LCD_3310.pbp"
    or
    include "LCD_7110.pbp"
    Most of the code is already posted here earlier (BIG thanks for that!), something is modified and something new.
    -Gusse-
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
