Using Nokia LCD - Page 3
Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 81 to 120 of 301
Thread: Using Nokia LCD
  1. #81
    Dec 2007
    Finland
    Question Extended ASCII, some problems
    Hi bitmaniac & all,
    I used bitmaniac's matrix.zip files to wake up my LCD with 16F876A and wake up was success
    Then I tried to add some new characters to EEPROM area (DATA), but EEPROM is quite limited. I made some modifications to (Lcd_SentChar, attachement) and removed all character from EEPROM area. Now I have both A-Z and a-z characters available, working fine
    Also I added some extended ASCII codes, like Ä,Ö,ä,ö but then I noticed problems? It seems that LOOKUP cannot handle extended ASCII codes? Error message was: Argument out of range. Least signficant bits used and there was no exteded ASCII on LCD
    LOOKUP2 didn't give any errors, but no extended ASCII characters on LCD.
    Can somebody help, how to show extended ASCII with LOOKUP command?
    Apr 2008
    Lisbon-Portugal
    Smile Rs232 nokia lcd 16f628
    I hall
    I know it's not very new, but I think is interesting.
    This program receive text information true rs232, display in a Nokia 3310 LCD capital and small letters, display 3 sizes off characters, variable and fixes size of characters, normal and inverted screen and character.
    I've test the program connecting the Tx of my Pc tru a 74ls04 and it works greatly with 3.3 v
    Have a nice time!
    Jun 2006
    Bangalore, India
    Question
    Hi HJota,
    Can you provide me the schematic you are using ?
  4. #84
    Apr 2008
    Lisbon-Portugal
    Thumbs up Schematic Rs232 nokia lcd 16f628
    Shahidali55
    You can trie my (not finish) web page, were I have all he information about this project.
    If you have any douts please tell me.
    Hope it helps you a little.
    http://pwp.netcabo.pt/hjota/
    (Soon I will publisgh the PCB picture)
  5. #85
    Jun 2008
    can someone pls post simple 3310 lcd example, where i can only put a pixel on my screen. i dont need code where i can display characters, pictures etc. Just as simple and compact as possible.
    Thank you...
  6. #86
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by theguru56 View Post
    http://www.picbasic.co.uk/forum/showthread.php?t=327
    Simple examples all over...
  7. #87
    Jun 2008
    But i'm newby to ccs c and i am not able to translate given code into basic.,...,
  8. #88
    skimask's Avatar
    skimask Guest
    If you'd apply yourself, do a little bit of reading/looking/etc, you might (or might not) notice that not ALL of the code in the 80-odd posts is written in C.
  9. #89
    Jun 2008
    Ok, past few days i have been playing with different code examples and came to solution which is attached below (proov.zip). This code works fine on small pics (like 12f629, 12f675) but wont work on bigger pics (16f627/8), Can someone pls give me clue whats worng in that code.
    skimask's Avatar
    skimask Guest
    What's wrong with the code?
    1 - It'll never compile in PicBasicPro. Not today, not tomorrow, not ever.
    2 - It (the .bas, the includes, everything about it) it written for a 12F, not for the 16F series.
    3 - You're in the wrong place. Most likely www.picbasic.org is what you really want. Since this (http://www.picbasic.org/forum/showth...ght=nokia+3310) is where you got the code in the first place.
  11. #91
    Jun 2008
    Ok, ill try there.
  12. #92
    szovertoplcd's Avatar
    szovertoplcd Guest
    If you try to get the datasheets, I suggest you following datasheets center:
    www.pdfsea.com
  13. #93
    Dec 2007
    Finland
    Post Nokia 3310 and 7110 LCD command libraries
    I don't know how many is still using old (monochrome) Nokia LCD displays, but I do.
    To make it easier to write code for both 3310 LCD (PDC8544) or variants (Nokia 8210...) and 7110 LCD (SED1565), I made a common command library for both LCD types. So you can use same commands in your program and only change display and link right library file (see attachement for more info). Of cource there are more pixels in 7110 and therefore you must do some fine tuning for character/picture positions, but anyway it will work with a minimum effort. At least I hope so.
    I use this by including it to main program
    '----- LCD Setup -----
    include "LCD_3310.pbp"
    or
    include "LCD_7110.pbp"
    Most of the code is already posted here earlier (BIG thanks for that!), something is modified and something new.
    -Gusse-
    Just what I was looking for, thanks!
    Questions:
    (1) How do you recommend writing entire words "Hello World...". Do we really have to loop through every letter? Would be nice to issue a Lcd_Send_This("Hello World")
    (2) Do you use a large LOOKUP table or CASE for A-Z ??
    Right now I have a LOOKDOWN table for A-Z that gets the position and then uses that num*6 to LOOKUP the bits in my huge table (no eeprom here).
    (thoughts) Looking ahead I worry about not being able to use a VAR in LOOKUP. In the end, isn't that what I really want to display?
    Thanks again.
  15. #95
    Dec 2007
    Finland
    Post
    Check page 22 from Philips PCD8544 datasheet. It shows how characters are formed to LCD. If you are using 8x6 pixel fonts then you have to do 6 write operations (each of 6 column separately). This can be combined to one loop, so it writes one character or graphics at the same time. Yes, You have to loop through every letter.
    Thanks again.
    LOOKUP table or CASE are good options, even IF - THEN can be used. I have tried all of them, now using LOOKUP2. If you don't need all alphabets then some limited table or direct data to LCD can be an option. With direct data I mean that you make characters like a graphics, turning on/off DB7:0 data bits.
    In case you need A-Z and a-z then LOOKUP or CASE needs twice more space. Then external EEPROM becomes very handy.
    BR,
    -Gusse-
  16. #96
    Dec 2008
    Ploiesti, ROMANIA
    Hi to all !
    I use the hardware from here : http://www.picbasic.co.uk/forum/show...a+3310+display.
    I try to modify the code of N3310+PIC 12F675+DS18B20 for using PIC 16F628A, like in attachament. But...nothing on display ! Can someone tell me what I do wrong ? Thanks in advance !
    Hi!
    If you followed my schematic exactly, try the attached code.
    It works fine for me.
    Notice : Cs (PortB.3) must be Low ; Rst(PortA.4) needs a pullup ; Mode is disabled (you need another pin)
    Gianni
    Dec 2008
    Ploiesti, ROMANIA
    You are one Gentleman ! Thank You verry much ! It's work fine now !
  19. #99
    Dec 2008
    Ploiesti, ROMANIA
    Hi again ! I try to build one simple thermometer, based on schematic from GioppY and code from Ivica N., but with this code (attached) I see only some points, all over the display, and '85.0'. Some sugesstion ? What I do wrong ? Thanks in advance !
    Dec 2007
    Finland
    Post
    Quote Originally Posted by fratello View Post
    Try to clear the LCD, that should help. See my post (#95) couple of replies above for more info about LCD commands.
    Do you want to measure temperature more than once? At least there is no loop back to Main. Also I have noticed that DS18B20 gives 85 degrees for some time at the first start (when powered). This might be the reason why you see 85 and some some dots on your screen.
    BR,
    -Gusse-
  21. #101
    Dec 2008
    Ploiesti, ROMANIA
    Using the command "goto main" I have some results ; now the display show the correct temperature...but still remains some 'points'... (see foto). I try different code for LCD_Clear, but not results... Please, help me more ! Thanks in advance !
    Dec 2007
    Finland
    Post
    Could you post your entire code here? At least I did not see where you write "TEMP:" to screen. Also at which point you do your LCD clear routine. Problem might be in that code area...
    At least you managed to get DS18B20 to work. That's positive!
    BR,
    -Gusse-
  23. #103
    Dec 2008
    Ploiesti, ROMANIA
    Sorry...mea culpa ! This is the full code !
    Dec 2007
    Finland
    Post
    You are not using "LCD_Clear:" routine anywhere, so you are not clearing the LCD at any phase.
    Add this before "Main:"
    call LCD_Clear
    If that doesn't help, try to replace manual LCD write commands with SHIFTOUT. Similar what you have in "LCD_ByteOut:"
    BR,
    -Gusse-
  25. #105
    Dec 2007
    Finland
    Post Correction to last post
    I meant this (below) instead of "CALL"
    GOSUB LCD_Clear
    Why you are using CALL, shouldn't those be GOSUB instead?
    BR,
    -Gusse-
  26. #106
    Dec 2008
    Ploiesti, ROMANIA
    YES !!!! That work ! THANK YOU !
    I have learning again one more thing. Thanks to You, all members of this great forum. I'm happy !
    Now, I want to make the next step : "up-grading" the schematic from here - http://www.picbasic.co.uk/forum/show...7&postcount=35 for using with N3310 display. I will keep You on line ! All the best !
  27. #107
    Dec 2008
    Ploiesti, ROMANIA
    Now my project it is in this stage - see photo 1. I ask -again, sorry ! - for help : how to make like in photo 2 ? I do not understand how 'advanced' to next line (I think because of my poor english... ). I read the N3310 display .pdf and many examples, but still don't understand... Can somebody explain to me, please ?
    Dec 2007
    Finland
    Post
    You want to have "Temp:" on Row0 and temperature reading on Row1? If this is the case then I recommend to use library from post #95.
    This is how you can move positions on screen.
    PosX=[X-axis pos]:PosY=[Y-axis pos]:Gosub Lcd_GotoXY
    1) Goto PosX=0 and Pos=0
    PosX=0:PosY=0:Gosub Lcd_GotoXY
    Then add LCD write routines to display "Temp:"
    2) calculate where you want to write on Row1.
    X-axis
    84 pixel, 6 pixel width per character = 16 character per line
    Temp: -> 5 character -> 5 * 6 pixel = 30 (start pixel for temp reading)
    PosX=30
    Y-axis
    48 pixel, 8 height per character = 6 character per column
    1st row = 0, 2nd = 1, ... 6th = 5
    PosY=1
    PosX=30:PosY=1:Gosub Lcd_GotoXY
    Then add LCD write routines to display temperature reading.
    To take library into use, insert this to your code and save & unzip-file Nokia_LCD_3310_7110.zip to same directory (or mod path).
    You might want to use also other library functions... it might easier your life...
    BR,
    -Gusse-
  29. #109
    Dec 2007
    Finland
    Post
    Library file is in post #93, not #95. Sorry!
    BTW, why I cannot modify/edit my own posts after pressing "Submit Reply" -button??
    BR,
    -Gusse-
  30. #110
    Dec 2008
    Ploiesti, ROMANIA
    Thank You ! ... I modifiy the code like in attachament, but now I have nothing on display ... After the line of code that I inserted it's need to put another's commands ? Only this single line it's not enough ?
    ( ..... Char = 18
    call PrintChar
    PosX=30 : PosY=1 : Gosub LCD_GotoXY
    if TempH > 99 then
    Char = 1
    call PrintChar
    Char = 10 ' + plus
    if Predznak = 1 then Char = 11 ' - minus
    call PrintChar
    Char = (temph dig 1)
    call PrintChar
    Char = (temph dig 0)
    call PrintChar
    Char = 12
    call PrintChar
    Char = (temperature dig 3)
    Call PrintChar
    goto main )
  31. #111
    Dec 2007
    Finland
    Post
    ( ..... Char = 18
    call PrintChar
    if TempH > 99 then
    Char = 1
    call PrintChar
    Char = 10 ' + plus
    call PrintChar
    call PrintChar
    call PrintChar
    Char = 12
    call PrintChar
    Call PrintChar
    goto main )
    Please, take a look how I did with my accelerator demo application
    Nokia LCD with 3D-accelerometer.
    In this demo, I didn't use library file, but all relevant LCD routines are under "LCD stuff" section in the code (zip-file).
    You can always copy content of library to your code, if you have problems with included files.
    One line is enough, it is so simple
    BR,
    -Gusse-
  32. #112
    JLbart's Avatar
    JLbart Guest
    Smile Does anybody know a ZorroGPS?
    I found a SatNav software on ZorroGPS.com, Has anybody used this software?
  33. #113
    Dec 2008
    Ploiesti, ROMANIA
    With the code below I have the results like in photo ! Thank You all for Yours cooperation !
    Note : The dual function of reading two sensors DS18B20 it is not yet ready !
    Dec 2008
    Ploiesti, ROMANIA
    Me again ! My thermometer with two sensors is ready !!!!! Works great !!!!!
    Unfortunate I can't making one best looking for display ...I don't -yet- understand how to display 'graphical things'....One border mybe is necessary...Every improvement will be apreciated ! Thanks - again _ to all !
    All the best ! (...and sorry for my poor english...)
    Not so poor . . . Middle Class , Project coming along nicely, hang in there, you're getting it.
  36. #116
    Dec 2008
    Ploiesti, ROMANIA
    I did it ! This is my final version ! I'm happy !!!
    I wish You all the best !
  37. #117
    Good job!
    Don't give up!
  38. #118
    Dec 2007
    Finland
    Post
    Great! More Nokia LCD applications are always welcome
    I have plenty of Nokia color LCD. Maybe that is next step... , but not soon...
    BR,
    -Gusse-
  39. #119
    Dec 2008
    Ploiesti, ROMANIA
    Hi to all !
    Based on the code from here : http://www.picbasic.co.uk/forum/show...7&postcount=35, I intend to use the Nokia-LCD for the thermostat; I attach the schematic. Please, help with TRISB,TRISA,PORTB,PORTA,OPTION_REG setting, because, even I read the datasheet, I don't understand why Mr.GioppY say :
    TRISB = %11000010
    TRISA= % 10100010
    In the schematic I see : RB6,RB7 not used - why "1" ?
    RA7 not used - why "1" ?
    Can someone explain me ? Thanks in advance !
  40. #120
    May be he used it for some tasks and forgot to make it Output (0).
    So if you do not intent to use them, make it output. If you still want to keep it Input suggest to tie pull up or pull down resistors. Do not let any pin float.
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    By skimask in forum Code Examples
    Last Post: - 28th September 2011, 02:43
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
    Last Post: - 27th June 2007, 00:07
  5. LCD will not start
