String & WRITE
Results 1 to 17 of 17
Thread: String & WRITE
    Dec 2017
    Default Re: String & WRITE
    Hello everybody,
    Although this topic might be quite old, I would like to "try my luck" to sort out a problem that bothers me for some time.
    From the very begining want to state that I am rather a noobie in relation with PIC's and peculiar with its EEPROM operation and actualy this is my first interaction with this forum.
    On short, I use DEBUGIN command to capture a 16 characters alphanumeric strings sent from a PC, something like following example:
    85D4E88A3B52AA40 (or more corect said "8","5","D","4","E","8","8","A","3","B","5","2","A ","A","4","0").
    I do need to WRITE these characters into onchip (PIC16F88) EEPROM, location 0, as pairs consisting of 2 characters in 1 Byte.
    At the end of operation the first location of EEPROM memory must looks like this: 85 D4 E8 8A 3B 52 AA 40.
    Unfortunately I have ended up with this result: 85 44 58 81 32 52 11 40.
    Concernig the pairs of data within the string please note that there are several kind of possible combinations:
    - 2 digits (i.e. 85, 40);
    - 2 characters (i.e. AA);
    - 1 digit and one character, in this order (i.e. 8A, 3B)
    - 1 character and one digit, in this order (i.e. D4, E8)
    Mention that I have used and adapted BigWumpus' above proposed algorithm.
    It works perfectly as long the string contains only digits (0-9).
    However, it fails whenever HEX like characters (A,B,C,D,E F) come into picture.
    Any help to sort out this problem will be highly appreciated.
    Many hanks in advance and wishing you all a Happy and Prosperous New Year !
    Best regards,
    Andrew
    Welcome to the forum!
    If you use the HEX modifier while receiving the ASCII string each byte in the string/array will contain the numeric value (0-15) represeneted by the ASCII character (instead of the ASCII code FOR the character). Once you have that it's just a matter of taking the first byte, shifiting it 4 steps to the left so it ends up at the four most significant bits and then add the next byte.
    Dec 2017
    Good day Henrik,
    Many thanks for your swift reply and suggestion.
    Regarding your indication to use HEX modifier all noted. However I am not sure what is the correct SYNTAX for it...
    Mention that I am using PICBASIC PRO 2.60C & MCS 3.0.0.5 and below follows a fragment of code I try to implement:
    i VAR BYTE
    j VAR BYTE
    new_data VAR BYTE[16] 'this array variable will store incoming data from serial port
    Dummy VAR BYTE
    test VAR BYTE[16] 'this array variable will store data READ from EEPROM
    begin:
    DEBUGIN 150, continue,[str new_data\16] 'receive data from PC
    For i = 0 To 7 'read previously stored into EEPROM
    READ $0+i,test[i]
    Next i
    'compare the income string data with one withdrawn from EEPROM and case they are different only then refresh the EEPROM
    'this is done to avoid unnecessary time consuming writting / wasting the EEPROM
    IF (new_data[0] <> test[0] AND new_data[1] <> test[1] AND new_data[2] <> test[2] AND new_data[3] <> test[3] AND new_data[4] <> test[4]_
    AND new_data[5] <> test[5] AND new_data[6] <> test[6] AND new_data[7] <> test[7]) THEN
    For j = 0 to 7
    Dummy = (new_data[j<<1]<<4)|(new_data[(j<<1)+1] & $F) 'Mr. BigWumpus algorithm to split the data into 2 bits pairs
    Write $0+j,Dummy 'write down into EEPROM the pairs consisting of 2 bits
    next j
    DEBUG "EEPROM data updated !"
    continue: 'here follows some regular routines to execute case DEBUGIN timeframe (150 ms) is exceeded
    Kindly indicate the necessary corrections in order to have a functional code, in terms of suggested HEX modifier.
    Also, I do believe that READ instruction need to be revised too in order to function as expected.
    I really appreciate your help in this respect.
    Many thanks in advance and have a nice day ahead and a Happy New Year !
    Best regards,
    Andrew
    P.S. Kindly accept my apologies case this message appears posted twice. During first editing attempt my computer got stuck
    It looks like the HEX modifier can only do 8 digits "by it self" so one way is to resort to the good old FOR loop
    For i = 0 to 15  ' We're doing 16 hex digits
      DEBUGIN 150, Continue, [HEX New_Data[i]]
    NEXT
    I haven't looked closely at BigWumpus packing/splitting code, so I don't know if it needs modifying for this to work properly but give it a try as is and see what it does.
    OK
    Whether you wish to refer to a value in its decimal, hexadecimal, or binary format, when storing to the EEPROM, you are simply storing that value. When you READ it back, you may need to format it in its hexadecimal format for sending information serially, or displaying to an LCD. It looks like you are receiving these digits as ASCii, which allows for letters A-F. My approach would be to first convert the ASCii characters into Nibbles, then group them together into Hex. Finally you can store the Value in your EEPROM.
    To convert an ASCii character to a Hex nibble, subtract $30 from the numeric value of that nibble. Characters 0 >> 9 will be their 0 >> 9 raw value. Capital letters start at $41. Example, actual ASCii value of $41 = "A". You could use IF New_Data > $39 THEN : GOSUB DecodeLetters, ELSE : GOSUB DecodeNumbers. Using the shift and mask code listed previously, group your high nibble and low nibble together to create a new and complete byte value. Repeat for each 2-character grouping. When READing from the EEPROM, use the HEX modifier to send "Value" serially (ASCii representation). The key is that your ASCii value is $30 + Numbers (0 >> 9) and $37 + Letters (A >> F); conversely, ASCii - $30 = 0 >> 9 value while ASCii - $37 = A >> F values.
    When you use the HEX modifier with SEROUT, DEBUG, LCDOUT, HSEROUT, ARRAYWRITE and so on it converts FROM a numeric value TO an ASCII string representing the numeric value as hexadecimal. In other words a value of 127 becomes a "7" and a "F".
    Likewise, when you use the HEX modifier with SERIN, DEBUGIN, HSERING, ARRAYREAD etc it converts FROM an ASCII string (or single character) representing a numeric value as hexadecimal TO the actual numeric value. In other words the "7" and the "F" becomes 127.
    mpgmike does a good job of explaining how you convert ASCII to the numeric value that the "text" represents but what I'm trying to say is that you don't have to do that "manually" because the HEX- (and DEC and BIN) modifiers works both ways and does the job for you when used with a command that supports them (which DEBUGIN does).
    It would be interesting to see if any benefits (size- or speedwise) can be gained from doing the conversion "manually" instead of letting PBP handle it for you using the built in modifiers.
    Happy new year by the way!
    Dec 2017
    Hello everyone,
    I am glad that my "initiative" to re-open this topic has got such an echo.
    Will give a try to presented methods and will reverd with results ASAP.
    Meanwhile have a joyful and prosperous New Year !
  1. WRITE: One more PBP 2.60 Surprise ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 10:10
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  3. Microcontroller with 2 way paging application problem
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. Storing Strings using the Write command
    Last Post: - 1st November 2005, 12:31
