PortA as Inputs in PIC16F628A program
Results 1 to 13 of 13
    let's do a try... sorry if i'm wrong.. i try
        peek PORTA,B0
        if Bit1=1 then transmit ' iF PORTA.1=1 then transmit
        GOTO Main
    mramos's Avatar
    mramos Guest
    Quote Originally Posted by mister_e
        peek PORTA,B0
        GOTO Main
    The peek reads porta into B0 (you did not include where you have porta defined (unless PB has it defined.. I doubt it, maybe PBP does, I made an include to drop in my code since BP is not a complete product). B0 is byte 0 in the chip.
    Now that it is in B0, you need to IF against B0. So you can AND it (as it is a byte not a bit) with %00000010.
    i based my example on a PBC code example on the Melabs Website.
    adcx.bas ==> http://www.melabs.com/resources/samples/x1/pbc/adcx.bas
    Our friend already defined PORTA, TRISA and so on on his First post. Read back everything.
    As far as i know B0 is a pre-define variable in PBC
    BIT1... comes from the PBC code example ( ... ok ok it was BIT2) and nowhere it was pre-define. By their example it seems to return or set the Bit value of B0 variable.
    As i said, i tried. I don't have and i don't use PBC.
    Let's see what are the result of someone using PBC.
    Mentor, Ohio
    Smile
    Hello,
    If I recall correctly B0 is a byte variable that can be tested for its individual bits. So Mister E is correct. If you peek at a port and have the byte put into the variable B0, then you test the individual pins of the port by testing the bits. Bit0 would be the same as PortA.0 for example. This should also be able to be done with variable B1. It has been a few years since I worked with PBC.
    It is a complete product. It serves a specific purpose. Is it the answer to programming with Basic, NO. But it does fill a need if you use it correctly. In my case it didn't fill my need because of what I was trying to accomplish so I bought the upgrade to PBP.
    BobK
    BobK, i think our friend mramos is in a kind of PMS or bad mood anyway... http://www.picbasic.co.uk/forum/show...05&postcount=3
    timmoore47's Avatar
    timmoore47 Guest
    Quote Originally Posted by BobK
    Hello,
    BobK
    What are PBC's limitations? I've just bought it and wondered what extra goodies which might be useful to me, might be in PBP?
    Tim
    Full comparison can be made from the MeLabs website and downloading and comparing the manuals from the two products, but as a (incomplete) summary...
    Handy commands such as LCDOut (and others) that save a lot of hassle.
    No restrictions on PIC pins and the ability in being able to alias them sensibly.
    No restrictions on assigment of variables (RAM) and the ability to alias them.
    Powerful IF THEN ELSE ENDIF structure permitting unrestricted nesting.
    Easy and direct access to PICs Registers without convoluted PEEKs and POKES.
    Ability to embed Programmer CONFIG directives.
    The list goes on...
    The paradox is that it is the Professional Programmers who have the knowledge and expertise to make PBC do anything they want, yet it is a product aimed at the bottom-end hobbyist. Whilst it is PBP that has all the easy to use features a novice needs, but it is aimed at the Professional. Time is money and life is short... how much of your life do you want to devote to your programming?
    mramos's Avatar
    mramos Guest
    Quote Originally Posted by Melanie
    The list goes on...
    No PMS, I feel IF and ENDIF are part of a good compiler (is one every on I have). And I will make PBC do all I need now that I know its limits.
  1. Erratic analog inputs .
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 10th October 2009, 23:34
  2. Problem with porta for 16F886(PIC 28X1)
    By Anghel Cosmin in forum Off Topic
    Last Post: - 26th February 2009, 14:07
  3. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 00:22
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
