Transformerless Power Suppply
Results 1 to 40 of 76
    Jan 2006
    Istanbul
    Quote Originally Posted by psdayama
    I have designed and made a fridge controller (Blind type) with 555 and
    similiar transformerless power supply some 3-4 years ago. I have used
    normal 680n / 250V capacitor --( our system is 240V 50Hz) and those are
    working nicely last 3-4 years and saving 100s of Rs. every month for the
    users without any recall.
    Now it would be a good time to post that schematic here.
    BTW; let me remind you that Melanie has a Klingon cloaking device.
    Take a hundred engineers and give them the same problem, and you're likely to get a hundred different solutions, and each will argue that thiers is the best approach. I think this thread has been pretty much done to death, and there's more than enough information here for anyone but the most inept to design their own. And they, through natural selection when playing directly with the supply mains, will ensure that the standards remain high for the rest of us on the forum.
    Dec 2005
    Quote Originally Posted by sayzer
    Just do a web search for X-10 schematics. They've been using a metallised film cap and series resistor for many years in the millions of UL approved switches and modules they've sold.
    Italy
    About the resistors:
    (Click to enlarge the picture).
    Best regards,
    Luciano
    Jun 2005
    Mumbai,India
    Post Fridge controller
    Hi sayzer,
    well here is the schematic. Im not so good in drawing like U.
    I had a fridge which had thermostat gone bust. So I made this ckt and
    saved lot of energy 0.75KWHr /day instead of 5KWHr/day. I also found
    that most of fridges have improper settings evenif the thermostat is OK and
    there is lot of frost and they consume abt 3-4 KWHr/day. So making a
    commercial unit costing Rs.400/- ( $9 appx.) have installed in abt 20-30
    homes and they are all saving energy down to 1KWHr/day.
    The consumption of unit is less than 05VA and there is no area even feeling
    warm. I cant afford to use X2 capacitors in this as that will push cost of unit.
    Aug 2008
    Can someone explain to me how the 240VAC after rectification can come down to +12VDC?
    Quote Originally Posted by Pic2008 View Post
    Are you kidding me? I have enjoyed the arguments a lot, and from the first post to the third last (subtracting yours & mine of course), I have come across 2 to 4 circuits all making 12VDC. Check them out going back few posts (Remember to use X2 capacitors with mains - else Melanie would not like it - in case she comes across your circuit )
    ___________________
    WHY things get boring when they work just fine?
  1. Transformerless Power Supply of 1A at 5Volts!
    By Ioannis in forum Schematics
    Last Post: - 10th September 2016, 21:17
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 07:07
  4. Replies: 10
    Last Post: - 16th October 2006, 18:23
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 2nd July 2006, 23:13
