Transformerless Power Suppply
Results 1 to 40 of 76
    You just have to walk down any High Street in any Town, anywhere in the world to see what I mean...
    Feb 2004
    Germany
    Quote Originally Posted by Melanie
    I'm almost sure I know what you mean and hope you haven't taken my comment too serious ;-)
    regards
    Ralph
    Porto - Portugal
    Default without transformer...
    Be carefull, be very carefull, when using a power supply without transformer is like walking in the wire without the net underneath...
    Atached you can see the circuit I use to put some power ... in PICs and other stuff. I found this circuit some years ago when I bought a kit (K6713)from Velleman, its a IR receiver to switch on/off a load connected to mains trough a relay.
    One more advise, if by any chance you are planning to use this circuit in a touch sensor or similar do not forget to use two resistors in series for the sensor, the contour voltage for a regular 1/4W is less than 200V, unless you like to get a curly hair...
    regards
    nomada
    If you're still looking for components, attached PIC I've taken gives you an idea of what to look for... The 11V VDR is pretty small (VDR2 in this pic) - and also laying alongside with a view of a typical Capacitor you can use. If it's an X2 type you're OK, otherwise you'll have to fit one with a 400vDC rating. It's a real good idea to absolutely and positively mark the PCB that it's LIVE... even if it's just for yourself. Some time in the future you'll forget and it'll bite you.
    Jan 2006
    Thanks Mel, I have finally got some 275V X2 caps and some VDR's (I had to buy 100 of them but thats OK). So I'll sort out a PCB (well marked, and well housed) and let you know how it goes...
    Jan 2006
    Istanbul
    Hi Melanie,
    Going back to this post,
    Would that be too much to ask for your complete fan controller schematic?
    and, if possible, for the code also?
    I am having a similar inquiry and would like to see your approach.
    Or if there is anyone else who had a similar design.
    Hi Sayzer
    This product is still in volume production (about 1000/month), and I'm treading on thin ice just posting the PCB view (a couple of posts above) and some snippets out of the PSU schematic - the remainder if you're clever you can figure from most of the components in use and eliminating those I've already revealed... a licence for the complete Software and Schematics would cost... I envisage around $5K.
    Melanie
  1. Transformerless Power Supply of 1A at 5Volts!
    By Ioannis in forum Schematics
    Last Post: - 10th September 2016, 21:17
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 07:07
  4. Replies: 10
    Last Post: - 16th October 2006, 18:23
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 2nd July 2006, 23:13
