Transformerless Power Suppply
Results 1 to 40 of 76
    It's a 3-pin ONLY system in the UK. Yes you can get continental 2-pin shaver adaptors, but I'm told you men like to live dangerously in the bathroom.
    Let's just look at TB008 for a moment... and just consider...
    Neutral is grounded at the Power Station, and at the substation, and probably at the Building incommer... Here we have a fuse between Neutral and Earth... why? It's completely USELESS!!! If the fuse wasn't there (or it blows for whatever reason), you STILL have a FULL conductive path between LIVE and EARTH. Actually he's (I'm assuming 'he' as a girl I'd expect to know better *smiles*) even using EARTH as a return path of his circuit. Plug that circuit into most properly wired homes and the first thing that happens is the ELCB breaker trips! The author of TB008 should be prosecuted for the most dangerous suggestion you could possibly think of!!!
    I'm well aware of the square wave inverters... still... the great unwashed (general public) hasn't got a clue... which is why you can market complete crap and they'll still pay good money for it.
    Feb 2004
    Germany
    I'm not using any transformerless PSU's at all.
    Some time ago I could get hold of a large number of well designed switching PSU-units at about $0,50 each (stock/production overhead)
    They provide well regulated 7,5V @ 600mA
    and are very small in size.
    (Actually not more in PCB-Space than a good transformerless design would require since they are fully SMD)
    I could not even design and build any transformerless PSU at comparable cost.
    Why develop/build something that is already available on the market at lowest cost?
    OK,
    for someone selling 10thousands of units per year it is a different story,
    but if you are selling "only" several hundreds of units I still feel it is a good option to search the web for those stock overheads.
    The only rule is:
    get a sample before your bulk order and test it carefully.
    If the sample is OK (meets or exceeds the requirements):
    order a quantity that lasts at least to the planned production/life-cycle of your product.
    That way I have saved a lot of time & money.
    regards
    Ralph
    Feb 2004
    Germany
    Quote Originally Posted by Melanie
    Mel, I doubt you would risk your reputation by marketing crap just to make money.
    (please correct me if I'm wrong)
    regards
    Ralph
    You just have to walk down any High Street in any Town, anywhere in the world to see what I mean...
    Feb 2004
    Germany
    I'm almost sure I know what you mean and hope you haven't taken my comment too serious ;-)
    regards
    Ralph
    Porto - Portugal
    Default without transformer...
    Be carefull, be very carefull, when using a power supply without transformer is like walking in the wire without the net underneath...
    Atached you can see the circuit I use to put some power ... in PICs and other stuff. I found this circuit some years ago when I bought a kit (K6713)from Velleman, its a IR receiver to switch on/off a load connected to mains trough a relay.
    One more advise, if by any chance you are planning to use this circuit in a touch sensor or similar do not forget to use two resistors in series for the sensor, the contour voltage for a regular 1/4W is less than 200V, unless you like to get a curly hair...
    regards
    nomada
    If you're still looking for components, attached PIC I've taken gives you an idea of what to look for... The 11V VDR is pretty small (VDR2 in this pic) - and also laying alongside with a view of a typical Capacitor you can use. If it's an X2 type you're OK, otherwise you'll have to fit one with a 400vDC rating. It's a real good idea to absolutely and positively mark the PCB that it's LIVE... even if it's just for yourself. Some time in the future you'll forget and it'll bite you.
    Jan 2006
    Thanks Mel, I have finally got some 275V X2 caps and some VDR's (I had to buy 100 of them but thats OK). So I'll sort out a PCB (well marked, and well housed) and let you know how it goes...
  1. Transformerless Power Supply of 1A at 5Volts!
    By Ioannis in forum Schematics
    Last Post: - 10th September 2016, 21:17
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 07:07
  4. Replies: 10
    Last Post: - 16th October 2006, 18:23
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 2nd July 2006, 23:13
