You can use all the pause statements you want inside a BASIC interrupt, however, I don't recommend you place gosubs in your interrupt handler.
This exits the interrupt handler, and if it lands in a sub routine where you are not disabling PBP's auto-insertion of interrupt checking stubs, then it's going to go totally nuts on you.
Place all of your routines inside the interrupt handler, or set/clear some type of flags to indicate the interrupt source, then return, then act on the other sub routines as needed.
Also note that RCIF can NOT be cleared with RCIF = 0. The only way to clear RCIF is to read the fifo USART buffer until it's empty. Trying to clear this flag like you are, you're leaving it set, and never clearing the USART interrupt flag bit.
! but now I have the problem that the a/d conversion some times fluctuates(value's are not the same every querying + 1000 some times). Where can I begin to debug? Thx !
