Can some one please check my code out thanks
Results 1 to 6 of 6
    Sep 2005
    Default Can some one please check my code out thanks
    Hi there this is my first real bit of codeing for pic basic pro.
    Can some one please look over it for me and see if there are any mistakes or have any advice regarding it thank you
    The idea of the code is to control two pwm signals and output the result for a servo.
    When input one is in use it will control the output but when not in use ie in the neutral position of 1.5ms pulses then input 2 controls the output.
    when here is the code
    'servo control prog
    'set variables
    ch1 var byte
    ch2 var byte
    s1 = 150
    start:
    if ch1 < s1 then output1
    if ch1 > s1 then output1
    if ch1 = s1 then output2
    output1:
    pulsout portb.3,ch1
    pause 18
    goto start
    output2:
    pulsout portb.3,ch2
    pause 18
    goto start
    Sep 2005
    Default Any one??
    Any one?? care to look
    I think you should find a way to give a value to var ch1. As it is it will get a random number on startup.
    Sep 2005
    Default xcode
    thanks for the reply i have just seen my mistake thanks really it shound look like this then?
    'servo control prog
    'set variables
    ch1 var byte
    ch2 var byte
    s1 = 150
    start:
    pulsin portb,1,Ch1
    pulsin portb,2,Ch2
    output1:
    pulsout portb.3,ch1
    pause 18
    goto start
    output2:
    pulsout portb.3,ch2
    pause 18
    goto start
    Secound question how do i subsitue ch2 for a pot instead of a pwm signal would it look like this
    potportb.2,200,var
    would this give me the correct value to output to a servo?
    You may have to give us more details of what you are trying to accomplish. No one would "play" with you and build command by command your code or what evere.
    Give more input. What is you input signal. Is it Pulse? Is it from a PC? Is it from a pot?
    You are not clear. I said that your variable would need a value. Pulsin would give a value to ch1 but is it what you really want to do?
    Sep 2005
    Default hi
    Hi there thanks for your help i have anouther thread running in this same fourm its called How would i write this in pic basic pro (Servo controller)
    thanks
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  2. can't find include file!
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 10th November 2009, 08:44
  3. Manchester coding/decoding Code help
    By financecatalyst in forum Code Examples
    Last Post: - 25th August 2009, 19:05
  4. Code to control 4 LEDs and 2 servos
    Last Post: - 26th November 2008, 13:33
  5. changing code from 16F to 18F microprocessor
    By SCC_699 in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 13:27
