Speedometer Question
Results 1 to 5 of 5
    Feb 2005
    GREECE
    Question Speedometer Question
    Hello my friends,
    I am going to make a speedometer project using a pic16F628 microcontroller (for my rc model car) display the speed of my car on a display!!!
    I do not have enough knowledge about how can I measure the speed of my car.I read in the forum that you can do that using a hall effect sensor.What sensor is that?Please I need everything useful(links-projects-schematics ext)
    Also,how can I drive a Calculator’s LCD.
    Thanks in advance
    Nikos
    Bill H's Avatar
    Bill H Guest
    Default Speedo
    Hi there Nikos,
    A Hall Effect sensor is used to either count or measure the duration of a magnet going by.
    It is typically mounted near a drive shaft or wheel. A small magnet is attached to the moving part.
    There are two basic methods of caclulating the speed of the magnet going by. One is to count the number of times it goes by in a given time frame. Or, measure the amount of time it takes to go by in a single revolution.
    Both methods have tradeoffs. Research the COUNT and the PULSIN commands.
    Interfacing the calculator display is way too wide open. There are so many variables it's hard to address.
    Good luck as you climb the PBP learning curve.
    Bill H
    Feb 2005
    GREECE
    Thanks Bill,
    Do you have any expirence with any kind of hall efect sensor?
    Can you suggest me any chip?
    Feb 2005
    GREECE
    Do you thing that this Sensitive Two-Wire Chopper-Stabilized Unipolar Hall-Effect Switches A1140-43 is OK for my application?
    see datasheet:
    http://www.allegromicro.com/sf/1140/
    Bill H's Avatar
    Bill H Guest
    It looks like the Allegro Hall device should work fine.
    Bill H
  1. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  2. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 16:44
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Timer / CCP Question
    Last Post: - 2nd November 2005, 09:22
