Nothing wrong there.
There are two different actions that can change the way INT_ENABLE works with version 1.10.
DEFINE INT_ENABLECLEARFIRST 1 ; (default)
With the above define, which is also the default, whenever you INT_ENABLE, the flag is automatically cleared before the interrupt is enabled.
DEFINE INT_ENABLECLEARFIRST 0
Whith this define, the flag is NOT cleared.
This can dramatically change the results and cause immediate interrupts if the flag is already set.
If INT_ENABLECLEARFIRST is 0, then INT_ENABLE takes one instruction cycle.
If INT_ENABLECLEARFIRST is 1, then INT_ENABLE takes two instruction cycles.
INT_DISABLE always takes one instruction.
thanks for the clarification Darrel!
I look forward to the day where I don't have to read something 10 times ...and still not be 100% sure what it means! Until then please humour me - I'm using V1.1 of your interrupts ...when you mention the default is for your code to clear any interrupt flag (ie prior to enabling) , but then I got confused when seeing this accompanying snippet....
So, Pop quiz, should I....
a) should I be putting such a line at the top of my program?
B) modifying DT_INTS-14.BAS?
c None of the above (it's erhm..... done by default!)
thanks!
