Instant Interrupts - Revisited
Results 1 to 40 of 773
Threaded View
  1. #11
    The major issue you have with the Diolan loader is that it has Enhanced CPU mode
    enabled. I.E. XINST = ON.
    So code compiled with PBP simply is not compatible, and will not run on the PIC as
    expected unless you disable Enhanced CPU mode.
    Here's a simple example you can try. Make sure you set XINST = OFF, then run this;
    MyVar VAR WORD
    LED VAR PORTD.0
    Loops:
     FOR MyVar = 0 TO 100
       High LED
       GOSUB BLINK
       Low LED
       GOSUB BLINK
     NEXT MyVar
       Goto Loops
    BLINK:
        PAUSE 200
    Now run the exact same code, but set XINST = ON and give it a whirl.
    Once you flip that switch to enable Enhanced CPU mode, ALL your code needs to be using
    the extended instruction set. Try it with ACCESS EQU 1 as well. Still no go.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
