Instant Interrupts - Revisited
Results 1 to 40 of 773
    Question
    Am I the only one confused by the "ALL_INT -- Global Interrupts" interrupt source?
    ALL_INT references the GIE bit (Global Interrupt Enable).
    You can use it like this ...
    @  INT_ENABLE  ALL_INT
    @  INT_DISABLE ALL_INT
    Someone here wanted it, but frankly I think it's easier to just alias the bit, then do GIE = 1.
    You can not assign a Handler to ALL_INT as an Interrupt Source.
    Apr 2006
    GearSweaterMountain, The Netherlands
    Darrel,
    Thanks for the DT-INTS modules, it's an awesome piece of work. It makes interrupt handling so much easier !
    I found this topic because i got stuck using the DT-INTS-18 within code that i was compiling using the 8.43 version of mplab. I got the same error116 over and over again, except when i commented out DT-INTS includes and ASM piece. Microcode studio compiles the exact same code without any error ...
    However removing the -K# parameter did the trick, it compiles flawless, exept for the fact that the Mplab SIM can't SIM anymore.
    Did you ever discover a workaround or did you get some more info from melabs ?
    Best regards,
    UB
    Yes I did.
    See this post for the MPLAB fix.
    http://www.picbasic.co.uk/forum/show...26&postcount=3
    Apr 2006
    wohoo Darrel, Thanks !
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
