Hello Unregistered ,
Originally Posted by Darrel Taylor You should NOT set INTCON, PIEx, PIRx, IPRx or any other interrupt related registers manually. DT_INTS handles all of those bits for you. So where in D_INTS do you configure if you want to trigger off a rising or falling edge for something like INT0 ? Thanks, Andrew
This is supposed to be done in the option register, isn't it? DT-INTS are not for settings. Ioannis
www.signalcom.gr
Originally Posted by Ioannis This is supposed to be done in the option register, isn't it? DT-INTS are not for settings. Ioannis See my first post - Darrel says not to set the interrupt registers manually. Andrew
This one you should set it yourself. Otherwise how would the system know what you want? Ioannis
View Tag Cloud
Forum Rules
