Instant Interrupts - Revisited
Results 1 to 40 of 773
    Default Time to respond to an interrupt.
    I think next one Darrel has to answer, but if anyone knows...
    How fast will the DT-INTS 14 interrupts (with PBP service) respond to a PORTB Interrupt on change?
    Or better put, how many cycles will it take?
    I am testing a Wiegand-26 reader the has 48uSec pulses every 2ms and at 4MHz the 16F628 chip does not feel it at all.
    Another reader the has 0,38ms pulse is OK with the 16F628. The PIC is running rather slow at 4MHz.
    I'd prefer a way to calculate the time it takes to respond on an Interrupt.
    My service test routine is something like this:
    CardReader:
       if d0=0 then
            array[index]=0
            index=index+1
        if d1=0 then
            array[index]=1
            index=index+1
    @ INT_RETURN
    P.S. After some testings I found that the pulse must stay at more that 150uSec for the PIC to grab it. Thats it at 4MHz.
    Sorry I missed the Edit window time.
    The 150uSec is really 115uSec...
    Dec 2008
    Los Angeles, CA
    Question Which type of interrupt is easier to implement?
    DT,
    I have only used interrupts once, (using Instant Interrupts) based on your clock routine. I am starting a design in which I want to again use your interrupt routines, (and I admit I haven't read all your examples and documentation yet). I'm at the point where I'm making a first guess at pin assignments on a PIC18F67J60. I know I'm going to have to use the clock output of a rotary encoder as one interrupt source, and a generic 'some button has been pushed' kind of interrupt from a bunch of PCF8574's as another. Being really new at interrupts, which would more straightforward to implement... the PortB 'onchange interrupts', or individual B0 (Int0), and B1 (Int1) dedicated interrupts?
    Thanks much,
    Len G.
    It really depends on what you need to catch.
    If you only need to catch either the Rising or Falling edge of a signal, then it's much easier to use INT1, INT2 and INT3.
    But it you need to catch both edges, then the best route is RBC_INT (PORTB Change) on PORTB.4-7.
    So I'd guess buttons on INT?, and encoders on RBC.
    Dec 2008
    Los Angeles, CA
    Thank you.
    Nov 2008
    Hi Darrel,
    i use your instant interrupts on a 18F6722.
    A question to the interrupts:
    I want to use a timer which shall make 1sec ticks and i have both uarts receving commands from other devices. I also have two subs writing and reading via I2C-Bus to some internal devices. Problem: If having more and more activity on the i2c bus and also interrups are coming via the uarts, the timer is getting slower (2 - 3 sec) depending on the activity.
    All interrups are defined as high priority interrups.
    Any idea?
    Ralf
    Quote Originally Posted by ralfmayr View Post
    All interrups are defined as high priority interrupts.
    Any idea?
    Hi Ralf,
    Do you have PAUSEs in your handlers?
    Interrupt handlers should be as fast as possible, get in - do only what needs to be done - and get out.
    If for instance it were writing to I2C EEPROM then sitting around waiting 10mS for each write to complete, then no other interrupts can occur during that time that it's doing nothing.
    If you have pauses, or long strings of data being sent or received, then those handlers should be LOW PRIORITY. Then with the Timer still in High Priority, it won't miss a beat.
    hth,
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 5
